Where is History folder?
L
In Window's XP, there is a history folder that records all activities of the
PC, it is at c:\user\local \local settings\history. Does anyone know where to
find this folder in Vista?
A
Andre Da Costa[ActiveWin]
c:\users\you_username \appdata\local\microsoft\windows\history
If you don't see it, make sure that Show Hidden files and folders is checked
(Organize > Search and Folder Options > View
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog/cns!E8E5CC039D51E3DB!9709.entry
"lily" <lily@xxxxxx> wrote in message
news:45B71D44-77C0-42CE-9578-DF2A60A3454E@xxxxxx
> the
> to
E
With IE 7.0 opened go up to Tools.
To Internet Options.
Click the Settings button under Browsing History.
Under Current Folder it shows you where they are.
> the
> to
J
followed the path through all that was recommended but there is no
History folder under Microsoft !!!
On Tue, 4 Dec 2007 19:20:01 -0800, lily
A
The only other recommendation then is to do it from within Internet Explorer
> Tools > Options > General (tab) > under 'Browsing History' > Settings
Andre
"Jim" <jfk666@xxxxxx> wrote in message
news:cohdl3ls082vpk0teje4g22bvfptd8rn82@xxxxxx
>>the
>>to
R
Ronnie Vernon MVP
Jim
Click Start and type shell:history In the results click the History
folder.
The actual path to this folder is:
C:\Users\username\AppData\Local\Microsoft\Windows\History
AppData is a hidden folder, so you will need to make sure that folders are
not hidden. To do this, open Windows Explorer and click Organize/Folder and
Search Options. Click the View Tab and select the 'Show hidden files and
folders' option.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
>>the
>>to
J
I found it through the IE7 Tools option....TX for your help !!
