why wont my .psd file sync?
C
CF
I have a .psd (Photoshop) file thats only 1.8Mb in my sync folder between two
OS X Macs. Its currently the only .psd file in my sync folder but there will
be more! It wont sync at all between the two machines - I have transferred
the file to both computers via a usb drive to see if the problem was computer
specific, its not, it doesn't matter which end the file is put in, it wont
sync. I have also tested the sync folder with other files to make sure the
sync is actually working, it is...works fine with any other files so far,
just not the .psd file.
any ideas?
J
Jason Dunn
I saw the same thing a while back, but when I tried to duplicate it later
for the FolderShare team, I couldn't. I have no idea why it happened in the
first place, and neither did they. So I don't have any solution other than
to suggest you ZIP it and I bet it will transfer over...if it happens with
other PSD files, there might be something the FS can investigate....
Jason Dunn
www.digitalhomethoughts.com
R
retromandc
Yeah I'm having the exact same problem since upgrading from foldershare to
Live Sync. pretty much the program is now useless to me. can't pull PSD's
down from my Mac at work.
> any ideas?
