WindowsUpdate error 0x802440A on RC1 b5728
P
Pasquale
Hi to all,
anybody have this problem?
When i click on "Check for Updates" in Control Panel - Security - Windows
Update window, the system perform a check for 2-3 seconds and reports the
error 8024400A. On the help guide, there is nothing.
How can i fix it?
I cannot download/install Vista and/or Windows Defender updates.
Thanks!!
Hi Pasquale,
I was looking for an answer to the same problem. Same version number Vista.
Same error code 0x8024400a when I check for updates for both Vista and
Windows Defender.
Greets, Ron
"Pasquale" wrote:
> Hi to all,
> How can i fix it?
> Thanks!!
J
Jeppe
Ron wrote:
> Hi Pasquale,
> Windows Defender.
> Greets, Ron
> "Pasquale" wrote:
>> Hi to all,
>> How can i fix it?
>> Thanks!!
I had same problem and this helped
-Stop the "Windows update" service.
-Create a new directory "C:\Windows\SoftwareDistribution.old"
-Move contents of "C:\Windows\SoftwareDistribution" into that new folder
(cut & paste)
-Start "Windows update" service.
Now update should work again. At least for me it did.
You can delete the .old folder
