winsock reset command
C
Claud
Can somebody please tell me what is the winsock reset command for windows
vista. I´ve tried typing "netsh" and subsequently "winsock reset" but it does
not work. I need the step by step explanation. Thanks.
C
Chad Harris
I'm not sure how you're applying it Claud, (I know it's often used to remedy
a firewall error and often after spyware has screwed the firewall up), but
you may want to look at:
http://support.microsoft.com/kb/937168/en-us
The command for Vista is Netsh Winsock Reset. You can also use this Winsock
Repair Tool (Should Work for Vista):
http://www.snapfiles.com/get/winsockxpfix.html
If you want to see all the switches, just type "netsh /?" (lose quotes) at
an elevated command prompt.
This also should apply to Vista:
http://www.microsoft.com/downloads/...46-131d-4617-bf68-f0532d8db131&displaylang=en
Also for reference:
http://support.microsoft.com/kb/875357/
hth,
CH
"Claud" <Claud@discussions.microsoft.com> wrote in message
news:7D83D3B2-EFEE-4512-8E1B-E230FF487527@microsoft.com...
> does
