Wireless connection
T
touch
I would like to add a "HP" desktop computer to my wireless router.
Is there a USB add on I can use to convert the desk top to wireless ??
Thanks for any and all help.................Tom
ps. I'm new to this and USB seems like the simple way to go.
J
Jack [MVP-Networking]
Hi
The way is to install a Wireless PCI card inside the Desktop.
Example, http://www.newegg.com/Product/Product.aspx?Item=N82E16833315041
However if it is impossible (or too complicate a USB is a good choice.
Example, http://www.newegg.com/Product/Product.aspx?Item=N82E16833315075
The two are compatible with all Windows x86 and x64
Jack (MS, MVP-Networking).
"touch" wrote in message news:[email protected]
