Wireless Internet Connection
G
Gonzalo
Hi there, i'm having some problems with my wireless connection. My Vista PC
says that i'm connected to the router and the internet, but I can't get into
the web. I reseted the router but nothing chaned. The explorer page gives me
this error: ieframe.dll/dnserror.htm.
I googled that error and i found a lot of forums about it, but no one has a
solution.
Has anybody had the same problem? And maybe the way to repair it!?
Thanks a lot
R
Rick Rogers
Did it work before?
Does it (the router) work with other machines?
Are you being assigned an IP (ipconfig /all)?
Have you flushed the dns cache yet (ipconfig /flushdns)?
Is it just IE or are other net-linked functions blocked?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Gonzalo" <Gonzalo@xxxxxx> wrote in message
news:E9C5F75E-BEDB-485D-916D-4B4F55C9FC41@xxxxxx
> PC
> into
> me
> a
> solution.
> Thanks a lot
G
Gonzalo
Hi Rick,
It's a new PC, the first day, explerer worked with a cell phone connection,
never gone with the router. I can't get connected to anything, messenger,
symantec, etc...
I have 2 other PC with win XP that work without any problem.
Sorry,but ihave no idea on how to flush the dns cache.
Thanks
"Rick Rogers" wrote:
> Hi,
> Did it work before?
> Best of Luck,
> > PC
> > into
> > me
> > a
> > solution.
> > Thanks a lot
R
Rick Rogers
Click start and type CMD, then right click the command entry in the program
menu and select 'run as administrator'. This will open an elevated command
prompt. From the prompt, run "ipconfig /all" and report back with the
following lines:
Node Type
IPv4 address
Default Gateway
DHCP server
Best of Luck,
news:991E37E2-5EBE-4208-BAE2-2C0CF0FE578B@xxxxxx
> Hi Rick,
> connection,
> symantec, etc...
> Thanks
>> Hi,
>> Did it work before?
>> Best of Luck,
>> > Vista
>> > PC
>> > into
>> > gives
>> > me
>> > has
>> > a
>> > solution.
>> > Thanks a lot
G
Gonzalo
Thanks Rick, i found it.
Everything looks normal to me.
> Hi,
> following lines:
> Node Type
> IPv4 address
> Default Gateway
> DHCP server
> Best of Luck,
> > Hi Rick,
> > connection,
> > symantec, etc...
> > Thanks
> >> Hi,
> >> Did it work before?
> >> Best of Luck,
> >> > Vista
> >> > PC
> >> > into
> >> > gives
> >> > me
> >> > has
> >> > a
> >> > solution.
> >> > Thanks a lot
G
Gonzalo
I flushed it, but everything is the same.
Thanks a lot Rick
> > Hi,
> > following lines:
> > Node Type
> > IPv4 address
> > Default Gateway
> > DHCP server
> > Best of Luck,
> > > Hi Rick,
> > > connection,
> > > symantec, etc...
> > > Thanks
> > >> Hi,
> > >> Did it work before?
> > >> Best of Luck,
> > >> > Vista
> > >> > PC
> > >> > into
> > >> > gives
> > >> > me
> > >> > has
> > >> > a
> > >> > solution.
> > >> > Thanks a lot
G
Gonzalo
#8
Hi, i followed the instructions that Rick gave me, you con read them in this
topic. I still can't get to use internet. Try reseting the router, sometimes
it works.
"Scaddows" wrote:
> Hi
> I have a similar probled. Please could you let me know exactly what you
> did. This may halp me connect my vista pc to my D-Link router
> Thanks
> Scaddows
G
Gonzalo
#10
Scaddows
8
Location
Sydney
#11
Wahay, I fixed it.
I updated the firmware as suggested by a number of you. I now have v 1.04.
The reason why I did not do this before was that the date on my firmware was leter than that offered by D-Link.
Wrong!
- I have an Australian model
- The user manual, instructions and help web links are American
- The label on the router says 1.03, but if you look on the Australian web page, it says 1.03 fixed the vista problem. So I actually had the US firmware
That aside, I pushed through and it all works.
Note: I ignored the advice to NOT update the firmware by wireless and was lucky. I think I should have done it by the cable.
Anyway thanks guys for the comments
The lessons learned are:
1 - never trust what the label says
2 - stay away from Vista!
3 - thank heavens for the internet community who came up with the answer.
Goodnight from OZ
G
Gonzalo
#12
That's a great news!!! Unfortunatly i have a digicom michelangelo wave router
(italian version) and i can't download any type of driver for it. Al the
other models have a driver to download, the only one that doesn't have is
mine. It should be updated, and Vista compatible as they say on their
website. I emailed them, but they are on holiday up to the 6 of January. I
hope to find a solution before that date, if not, i'll have to wait.
"Scaddows" wrote:
> Wahay, I fixed it.
> 1.04.
> Wrong!
> firmware
> answer.
> Goodnight from OZ
> Scaddows
