Wireless Networking
R
rowanhjl
At present I have a US Robotics 5416 Wireless Network card that Vista states
is not compatible. Is anyone aware of any wireless network products from the
UK that will work with Vista Beta 2 (PCI cards or USB). Many thanks, agc
U
u.s.e.TEC
Not sure if you found a solution but I will offer one, please though, make
sure you post back and let everyone know if this helped or not.
I had a similar problem with my D-Link 524 Router and a wireless D-Link usb
G122 adapter, Vista stated that my device was incompatible with the router.
Turns out that I forgot, when I setup Vista, I disabled all the WPA settings
within my Router and was trying to connect using those very settings from
within Vista. I guess Vista, not knowing the Router configuation, figured my
adapter was incompatible with my router because Vista does not display a
wireless open connection as being open like XP does. It took some digging but
I finally reallized this by allowing Vista to Diagnose the problem.
u.s.e.TEC PC Security Consulting
Specializing in User Security Education
