WLM & PPS FILES
R
Richard
This isn't a major issue but I'd like to understand what's happening and fix
it if possible.
Today I received an email with a .pps attachment. When trying to open it
from within WLM, I got the following error:
" This file does not have a program associated with it for performing this
action. Please install a program or, if one is already installed, create an
association in the Default Programs control panel."
I do not have Microsoft Office, but I do have the document viewers for Word,
Excel and PowerPoint. None of these applications show in the Default
Programs control panel. I don't know why except that the really aren't
programs, but "Windows Photo Viewer" does show. How is that any different.
I was able to save the attachment to my desktop and open it there either by
double-clicking or by right-clicking and opening with Microsoft Office
PowerPoint Viewer. I also noticed that the check box to "always use the
selected program to open this kind of file" was checked so the proper file
association appears to be proper.
I did test ".doc and .xls" attachments by sending attachments to myself and
they open just fine from within WLM. I don't know what the .pps problem is.
Is there way to resolve this issue so that I can open this type of file
directly from within WLM.
WLM - 14.0.8064.0206
Microsoft Office Power Point Viewer 2007 - 12.0.6425.1000
Microsoft Office Excel Viewer - 12.0.6425.1000
Microsoft Office Word Viewer 2003 - 11.0.8173.0 (I don't know why this one
is different)
Thanks,
Richard
B
Bruce Hagen
Unable to open .PPS attachments directly from Windows Mail or Windows Live
Mail
http://www.winhelponline.com/articl...ectly-from-Windows-Mail-in-Windows-Vista.html
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
"Richard" <Reply@newsgroup> wrote in message
news:%23Cp8RKIyKHA.5576@newsgroup
> fix it if possible.
> this action. Please install a program or, if one is already installed,
> create an association in the Default Programs control panel."
> Word, Excel and PowerPoint. None of these applications show in the
> Default Programs control panel. I don't know why except that the really
> aren't programs, but "Windows Photo Viewer" does show. How is that any
> different.
> by double-clicking or by right-clicking and opening with Microsoft
> Office PowerPoint Viewer. I also noticed that the check box to "always
> use the selected program to open this kind of file" was checked so the
> proper file association appears to be proper.
> and they open just fine from within WLM. I don't know what the .pps
> problem is. Is there way to resolve this issue so that I can open this
> type of file directly from within WLM.
> one is different)
> Thanks,
> Richard
I
Ildhund
Opening files is an OS thing, so it would have been helpful if you'd mentioned which OS you're using. See if the link helps: it applies to WLMail as well.
Noel
"Richard" <Reply@newsgroup> wrote in message news:#Cp8RKIyKHA.5576@newsgroup
> This isn't a major issue but I'd like to understand what's happening and fix it if possible.
> Today I received an email with a .pps attachment. When trying to open it from within WLM, I got the following error:
> " This file does not have a program associated with it for performing this action. Please install a program or, if one is already installed, create an association in the Default Programs control panel."
> I do not have Microsoft Office, but I do have the document viewers for Word, Excel and PowerPoint. None of these applications show in the Default Programs control panel. I don't know why except that the really aren't programs, but "Windows Photo Viewer" does show. How is that any different.
> I was able to save the attachment to my desktop and open it there either by double-clicking or by right-clicking and opening with Microsoft Office PowerPoint Viewer. I also noticed that the check box to "always use the selected program to open this kind of file" was checked so the proper file association appears to be proper.
> I did test ".doc and .xls" attachments by sending attachments to myself and they open just fine from within WLM. I don't know what the .pps problem is.
> Is there way to resolve this issue so that I can open this type of file directly from within WLM.
> is different)
> Thanks,
> Richard
R
Richard
Bruce & Noel,
Sorry about forgetting to mention that I'm running Windows 7 - 64bit. I
mentioned about everything else but forgot this one.
Anyway, both of you guys referred me to the same place and the fix works
great. Thanks for your help.
God, I love having access to these newsgroups. I got a correct answer within
15 minutes, in English and without getting "cauliflower ear" waiting on
hold.
Thanks again,
Richard
> fix it if possible.
> is different)
> Thanks,
> Richard
B
Bruce Hagen
You're welcome.
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
news:uTWnUgIyKHA.3304@newsgroup
> Bruce & Noel,
> within 15 minutes, in English and without getting "cauliflower ear"
> waiting on hold.
> Thanks again,
> Richard
>> different.
>> one is different)
>> Thanks,
>> Richard
S
slk759
One other suggestion not mentioned (not related to the fix for your issue) .
.. . . You are running the older version of WLMail. Consider downloading the
latest version, 14.0.8089.0726, and installing it.
> fix it if possible.
> is different)
> Thanks,
> Richard
M
Magsmom
I have been reading posts on this problem dating back to 2004 and none of the
"fixes" have helped me. I am running XP Home, SP3 and I have Windows Live
Mail "The latest version". I Have downloaded the latest version of Power
Point Viewer "2010" and I still have to save the e mail attachment and then
manually open the .pps file. I have the same problem if I am trying to use
Outlook Express. It seems that Microsoft builds problems into their programs
to try to force you to buy the expensive software packages like "Office". I
am a home user and I cannot justify spending $400.00 for a software package
just to be able to read and enjoy e mails. Since this problem has plagued
users for years, one would think that Microsoft would have addressed this
problem in the newest version of PPV.
> Mail
> Bruce Hagen
> MS-MVP [Mail]
> Imperial Beach, CA
> > fix it if possible.
> > different.
> > one is different)
> > Thanks,
> > Richard
B
Bruce Hagen
#8
PowerPoint Viewer 2010 is a recent release. I would suggest using PPV 2007
until someone like Ramesh Srinivasan comes to the rescue and creates a fix
for this latest mess my Microsoft.
PowerPoint Viewer 2007:
http://www.microsoft.com/downloads/...40-14E1-467D-8DCA-19D2A8FD7485&displaylang=en
And then apply the fix you saw for this PPV version.
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
"Magsmom" <Magsmom@newsgroup> wrote in message
news:03B0E465-DF39-4D76-B567-856A85A9E1B8@newsgroup
>the
> Live
> Power
> then
> use
> programs
> "Office". I
> package
> plagued
> this
>> Live
>> Mail
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>> > and
>> > fix it if possible.
>> > it
>> > installed,
>> > for
>> > really
>> > any
>> > different.
>> > either
>> > "always
>> > the
>> > myself
>> > this
>> > this
>> > one is different)
>> > Thanks,
>> > Richard
