WMI network adapter speed
D
Damon
Hello,
I am trying to run a query to get the network card's speed on remote
computers.
I tried win32_networkadapter and a couple of others which have a speed
property but mine are blank.
Any idea why mine are blank? is there another way to retreive network
adapter speed?
Thanks
O
/\\/\\o\\/\\/ [MVP]
damon, you need to look in the MSFT namespace
there is a wmiclass for it there, have no time to search good example, but
some googeling
and ADSI edit or my PowerShell WMI browser :
http://thepowershellguy.com/blogs/posh/archive/tags/WMI+Explorer/default.aspx
can help you out
if you can't find it, let me know I will look if can provide an example
later in the weekend
h.t.h.
Greetings /\/\o\/\/
"Damon" <Damon@discussions.microsoft.com> wrote in message
news:58A6B894-87CC-4C93-9674-6C4E33D5338E@microsoft.com...
> Hello,
> computers.
> adapter speed?
> Thanks
O
/\/\o\/\/ [MVP]
hmm,
I did find it but think I did run into some bugs :
$a = Get-WmiObject -Namespace Root\WMI -Class MSNdis_CoLinkSpeed
$a |% {$_.psbase.Properties.Item('NdisCoLinkSpeed')}
PoSH> $a | select [a-z]* | ft -a
Active InstanceName
NdisCoLinkSpeed
True isatap.{191B6C96-3488-457E-8A2C-03B54221751C}
System.Management.Managemen...
True Teredo Tunneling Pseudo-Interface
True Intel(R) PRO/1000 CT Network Connection
True Intel(R) PRO/1000 CT Network Connection - Virtual Machine Network
Services Driver System.Management.Managemen...
True WAN Miniport (Network Monitor)
True WAN Miniport (IP)
True WAN Miniport (IPv6)
True RAS Async Adapter
PoSH> $a |% {$_.psbase.Properties.Item('NdisCoLinkSpeed')} | select {$_.value}
$_.value
System.Management.ManagementBaseObject
PoSH> $a |% {$_.psbase.Properties.Item('NdisCoLinkSpeed')} |% {$_.value}
format-default : Exception retrieving members: "Not found "
PoSH>
so almost there, but still no speed
Greetings /\/\o\/\/
> some googeling
> can help you out
> h.t.h.
> Greetings /\/\o\/\/
> > Hello,
> > computers.
> > adapter speed?
> > Thanks
O
/\/\o\/\/ [MVP]
As I was very sure I did this before in PowerShell, I did search on my attic,
did find a Monad Beta 3 version, and did install it next to PowerShell
(confirming it runs on LongHorn :-)
And what I expected was $true , this did work before the WMI wrapper was
added in RC1. and this is a bug in the WMI adapter that does not correctly
handle ManagementBaseObjects anymore
I will post a bug on connect later
MSH F:\Windows\System32> $a | foreach {$_.NdisCoLinkSpeed} | ft [a-z]*
Inbound
Outbound
0
3221225
0
100000
0
1000000
0
1000000
0
1152
0
1152
0
1152
0
288
Greetings /\/\o\/\/
"/\/\o\/\/ [MVP]" wrote:
> hmm,
> Active InstanceName
> NdisCoLinkSpeed
> $_.value
> PoSH>
> Greetings /\/\o\/\/
> > some googeling
> > can help you out
> > h.t.h.
> > Greetings /\/\o\/\/
> > > Hello,
> > > computers.
> > > adapter speed?
> > > Thanks
O
/\/\o\/\/ [MVP]
filed this bug on connect as this makes inposible to get to a lot of WMI data
I think this is a major bug, voting helps getting it prio !!
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=288425&SiteID=99
while we are at it, if you not have done so check also this bug in the
adapter, that is also important, and did work correctly in Monad / MSH
https://connect.microsoft.com/feedback/ViewFeedback.aspx?FeedbackID=266942&SiteID=99
thanks,
Greetings /\/\o\/\/
> Inbound
> Outbound
> 0
> 3221225
> 0
> 100000
> 0
> 1000000
> 0
> 1000000
> 0
> 1152
> 0
> 1152
> 0
> 1152
> 0
> 288
> Greetings /\/\o\/\/
> > hmm,
> > Active InstanceName
> > NdisCoLinkSpeed
> > $_.value
> > PoSH>
> > Greetings /\/\o\/\/
> > > some googeling
> > > can help you out
> > > h.t.h.
> > > Greetings /\/\o\/\/
> > > > Hello,
> > > > computers.
> > > > adapter speed?
> > > > Thanks
O
/\/\o\/\/ [MVP]
I found a workaround, calling psbase 2 times, the first will not work the
second will :
PoSH> $c = Get-WmiObject -Namespace Root\WMI -Class MSNdis_CoLinkSpeed
PoSH> $v = $c[3].PSBase.Properties.Item('NdisCoLinkSpeed').value
PoSH> $v.psbase
PoSH> $v.psbase
Properties : {Inbound, Outbound}
SystemProperties : {__GENUS, __CLASS, __SUPERCLASS, __DYNASTY...}
Qualifiers : {}
ClassPath : MSNdis_NetworkLinkSpeed
Site :
Container :
So I could clean up the script like this :
Function Get-NetworkAdapterSpeed {
$c |% {
$name = $_.PSBase.Properties.Item('InstanceName').value
$s = $_.PSBase.Properties.Item('NdisCoLinkSpeed')
$v = $s.value
$v.psbase # Workaround for bug, first time call to psbase does not work
$p = $v.psbase.Properties
1 | select @{Name='Name';expression={$name}},
@{Name='inbound';expression={$p.Item('inbound').value}},
@{Name='outbound';expression={$p.Item('outbound').value}}
looks a bit strange but works for now
PoSH> Get-NetworkAdapterSpeed | ft -a
Name
inbound outbound
0 3221225
0 100000
0 1000000
Intel(R) PRO/1000 CT Network Connection - Virtual Machine Network Services
Driver 0 1000000
0 1152
WAN Miniport (IP)
0 1152
WAN Miniport (IPv6)
0 1152
RAS Async Adapter
0 288
Enjoy,
Greetings /\/\o\/\/
http://thePowerShellGuy.com
> thanks,
> Greetings /\/\o\/\/
> > Inbound
> > Outbound
> > 0
> > 3221225
> > 0
> > 100000
> > 0
> > 1000000
> > 0
> > 1000000
> > 0
> > 1152
> > 0
> > 1152
> > 0
> > 1152
> > 0
> > 288
> > Greetings /\/\o\/\/
> > > hmm,
> > > Active InstanceName
> > > NdisCoLinkSpeed
> > > $_.value
> > > PoSH>
> > > Greetings /\/\o\/\/
> > > > some googeling
> > > > can help you out
> > > > h.t.h.
> > > > Greetings /\/\o\/\/
> > > > > Hello,
> > > > > computers.
> > > > > adapter speed?
> > > > > Thanks
D
Damon
Thanks for the help,
I got it to work off of what you had done.
I just used linkspeed instead of colinkspeed.
It outputed correctly.
Thanks for all the help.
> second will :
> PoSH> $v.psbase
> PoSH> $v.psbase
> Qualifiers : {}
> Site :
> Container :
> $c |% {
> $v = $s.value
> Name
> inbound outbound
> 0 3221225
> 0 100000
> 0 1000000
> Driver 0 1000000
> 0 1152
> WAN Miniport (IP)
> 0 1152
> WAN Miniport (IPv6)
> 0 1152
> RAS Async Adapter
> 0 288
> Enjoy,
> Greetings /\/\o\/\/
> > thanks,
> > Greetings /\/\o\/\/
> > > Inbound
> > > Outbound
> > > 0
> > > 3221225
> > > 0
> > > 100000
> > > 0
> > > 1000000
> > > 0
> > > 1000000
> > > 0
> > > 1152
> > > 0
> > > 1152
> > > 0
> > > 1152
> > > 0
> > > 288
> > > Greetings /\/\o\/\/
> > > > hmm,
> > > > Active InstanceName
> > > > NdisCoLinkSpeed
> > > > $_.value
> > > > PoSH>
> > > > Greetings /\/\o\/\/
> > > > > some googeling
> > > > > can help you out
> > > > > h.t.h.
> > > > > Greetings /\/\o\/\/
> > > > > > Hello,
> > > > > > computers.
> > > > > > adapter speed?
> > > > > > Thanks
