WMP is working really strange...
M
MW27
It was working OK when I first install Vista. However, it is progressively
acting stranger.
First, when I tried to play an mp3 file, nothing will happen. Then when I
checked the Task Manager, wmplayer.exe was running. When I ended the process
and run the mp3 file again, it will work.
Then, it started 2 days ago, even by doing the above, I could only play one
song. The WMP window is totally locked up; none of the controls work; I
cannot even move or close the window; the visual effects (the scroll bar
indicating the progression of the song, and the visualiztion) stop working
after about 1-2 seconds also. It will just finish playing one song and stop.
Can anyone help?
MW27
Z
Zack Whittaker
Hmm... you might want to bug this - I've had no problems with WMP11 so far.
How to bug and different ways of submitting feedback:
http://www.vistabase.co.uk/welcome.php?bugreport
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"MW27" <[email protected]> wrote in message
news:[email protected]
> progressively
> acting stranger.
> process
> one
> stop.
> Can anyone help?
> MW27
N
Naseru
My advice: limit use of WMP to video only =)
I use WinAmp for most audio-related tasks, and WMP for video. (Same
installation choices as my XP machine.)
WMP has provided instability with audio files for almost ever -- mostly
because of improper mp3 file tagging (sometimes they're really mp2, encoded
weird, or just corrupt) --> winamp is more flexible with these things.
- naseru
> progressively
> acting stranger.
> process
> one
> stop.
> Can anyone help?
> MW27
A
Andre Da Costa [Extended64]
I would bug this:
For Feedback:
http://go.microsoft.com/fwlink/?linkid=55160
Feedback reporting tool:
http://go.microsoft.com/fwlink/?linkid=43655
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
> progressively
> acting stranger.
> process
> one
> stop.
> Can anyone help?
> MW27
M
MW27
Thanks a lot for your advice. However, the same thing happens when I tried
to play video with WMP. Now, I'm forced to use WinAmp...at least for now.
I'll send my feedback to MS; see if that is a bug.
MW27
> - naseru
> > progressively
> > acting stranger.
> > process
> > one
> > stop.
> > Can anyone help?
> > MW27
G
Guest
MW- [Sat, 3 Jun 2006 16:49:01 -0700]:
>Can anyone help?
No, but
It stopped responding for me. I went to the taskmgr,
wanted to Close it. Said it was waiting for my input.
Hm? So I hit the enter key and it came back to life.
No dialog was anywhere on the visible screen (only one
screen).
Lyrics don't work. Can't add, get a stupid msg about
language type - sometimes. Sometimes it appears to
work but nothing is added.
Ditto cover art.
It acts flakey and I've only used it 10 minutes. More
than once it seemed to go off into left field and do
nothing for a minute or so (it may have been waiting for
my input, but no indication was seen).
I'd like to get rid of Urge permanently, forever. I
have zero interest in it. (I'm not going to actually
use it anyway, and this is one reason; that's why wmp10
is on the bench.)
RTM is when? October? This'll be fun. I just hope
it turns out better than Wm5 did, which frankly isn't
even a finished product, not even now, a year later.
40th Floor - Software @ http://40th.com/
iPlay : the ultimate audio player for mobiles
parametric eq, xfeed, reverb; all on a mobile
