Won't read 2nd drive for Dual Boot
L
Aloha all. This may be OT, so maybe someone can point me in the right
direction...but I always get good replies here, and those people that don't
like OT...well, I'll givew them something to grump about...
I'm using Vista Home Premium. I have a spare 250GB SATA drive, so I thought
I'd install XP on that, then dual boot with my original Vista drive (AMD
Athlon dual-core at 3 GHz, 4GB RAM, 64 bit Vista Home Premium...when it
boots). The XP install seemed to go fine, in that the drive would boot up
alone (with the Vista drive disabled). But when I plugged my main Vista
drive in, the system would not boot up at all. I would get a Drive Read
error.
I don't get it. Both drives boot up fine by themselves, but when both are
running, neither will boot. Do I need to set one drive's jumpers or
something? I don't know SATA drive jumper settings, or if that's even the
issue.
Can someone give me at least a starting point?
Thank you.
C
Carey Frisch [MVP]
Windows Vista no longer starts after you install an earlier version of the Windows
operating system in a dual-boot configuration:
http://support.microsoft.com/kb/919529
"LMO" <lmo01@xxxxxx> wrote in message news:gp4njn$po0$1@xxxxxx
error.
issue.
Thank you.
L
Part two of my previous msg. Instead of XP, I installed Windows 7 beta on
the spare drive. By itself, it booted up fine. However, I wanted to have
Vista be the main drive, and Win 7 be the secondary drive, but when I have
both drives up and running, the Win7 drive always boots up. I get no dual
boot option.
Can I get the Vista drive to be the primary drive?
Thanks again.
> don't like OT...well, I'll givew them something to grump about...
> thought I'd install XP on that, then dual boot with my original Vista
> drive (AMD Athlon dual-core at 3 GHz, 4GB RAM, 64 bit Vista Home
> Premium...when it boots). The XP install seemed to go fine, in that the
> drive would boot up alone (with the Vista drive disabled). But when I
> plugged my main Vista drive in, the system would not boot up at all. I
> would get a Drive Read error.
> issue.
> Thank you.
C
Carey Frisch [MVP]
Use the Windows 7 beta DVD instead and follow the instructions in this KB article:
"LMO" <lmo01@xxxxxx> wrote in message news:#FIqAtToJHA.4372@xxxxxx
boot option.
Thanks again.
> issue.
> Thank you.
Carey;
Appreciate yout tutelege. Howqever, the article points to installing an
earlier version of windows with Vista. The latest problem I had was using
Vista and Windows 7 beta, which is newer than Vista.
Would it work if I installed 7 while Vista was still running on its own
drive? Would that make a difference?
Thanks.
"Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message
news:702C4BDC-66A6-4A06-B2A5-6F98BCA64BC6@xxxxxx
> article:
> boot option.
> Thanks again.
>> issue.
>> Thank you.
A
You have to go into bios setup and check the Boot Sequence. If Boot
Sequence just shows HD, then there's a secondary boot sequence for
hard drives called Hard Disk Boot Priority or Hard Disk Drives. Move
the Vista drive to the top of this list.
If the Vista drive is connected to the motherboard, and the bios is
set to boot from that drive while Windows 7 is installed, then dual
boot will be created on the Vista drive during Windows setup.
On Mon, 9 Mar 2009 21:04:50 -1000, "LMO" <lmo01@xxxxxx> wrote:
>Carey;
>Thanks.
>> article:
>> boot option.
>> Thanks again.
>>> issue.
>>> Thank you.
Dual Drive Saga Continued...
Okay, I have the Vista and Win7 drives loaded and working. Minor issue now
is that the Win7 drive seems to be the default drive. When the screen comes
up giving me the choice of which system to load, it is so brief that unless
I am sitting at the computer, with my hand on the Vista key, I miss it, and
the Win7 drive boots. Not what I want.
Is there a way to lengthen the time that choice screen stays up? Else, I can
try Andy's suggestion to go in to BIOS and change the default drive.
Thanks, all!
> issue.
> Thank you.
W
webster72n
#8
Re: Dual Drive Saga Continued...
"LMO" <lmo01@xxxxxx> wrote in message news:gp7a7h$v7s$1@xxxxxx
> comes up giving me the choice of which system to load, it is so brief that
> unless I am sitting at the computer, with my hand on the Vista key, I miss
> it, and the Win7 drive boots. Not what I want.
There is, you can press the pause/break button, but not tooo long, please.
Harry.
> Else, I can try Andy's suggestion to go in to BIOS and change the default
> drive.
> Thanks, all!
>> issue.
>> Thank you.
Final Chapter in this farce
Okay. I decided this was a PITA, not worth the results. I removed the second
drive and want to boot up normally into Vista Home Premium, as orginally set
up. However, when I boot up now, I am still getting the Dual Boot screen,
which offers Windows Setup, Windows 7, and Vista. If I don't quickly choose
Vista, it tries to continue with setup, then goes in to a reboot cycle.
HELP! How do I get rid of the dual boot screen, and just bootup into Vista?
Thanks!
> issue.
> Thank you.
SIW2
Re: Final Chapter in this farce
Hi LMO,
Type msconfig in Start search box - open it when it pops up.
Click the Boot tab. Highlight the Vista entry , click Set as Default.
You can also alter the Timeout figure to increase the time boot options are displayed at startup. Apply, Ok.
If you really want to delete a boot entry, highlight it and click Delete.
Hope it helps
SIW2
Thanks!
> issue.
> Thank you.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
#11
Vista, and presumably Win7, no longer use a boot.ini file to define or change the startup drive.
There is now BCD and the info is located in bios memory.
To change the default o/s you need to get a BCD editor.
Here is one. http://www.vistabootpro.org/
Do a google search for BCD vista for other options.
John
> Thanks, all!
>> issue.
>> Thank you.
