Word 2007 not responding
V
Veronica
Help! Word keeps locking up and gives the mesage "not responding" This worked
fine for 4 months and now suddenly it gives me this message when I want to
ope a saved file or close word. I find this very annoying. This office
program cost way too much money not to work. I have been told it could be
templates, but I am not an IT speacialist, so I need more detailed
information in order to fix the problem.
Thanks to anyone who may be able to help me.
G
Guest
You can test if it is templates by typing in Start Run
winword /a
If word works then it is templates.
"Veronica" <[email protected]> wrote in message
news:[email protected]
> worked
B
Bill Daggett
tmaxmill <[email protected]> wrote:
>I had the exact same problem. I did as you suggested and sure enough,
>it worked. Do I have to Start Run winword /a from now on?
Do you really think anyone is still monitoring this thread after a
freaking year?
tasaholic
Settle down kids !! Just goes to show,doesn't it..no matter how old the post..the advice is still relevant,and equally importantly,it just solved somebody's issue! Fantastic, I say !!
Mary C
Regardless of the age of the original post - this fix came up as 3rd on the list for Word 2007 not responding in Google.
I purchased Office 2007 about 3 months ago and have had nothing but trouble with opening Word since. I downloaded patches and fixes that I found months ago and nothing has worked until now.
typing "winword /a" worked!
Thank you!
Tom38
If others have similar problems that don't get fixed, you may want to look at my post with a similar problem that got fixed easily. Look at Microsoft Word 2003/2007 "not responding" ............... posted 11/28/09.
cwl7454
Banned
What I found out thru trial and process is that a couple of third party apps installed will cause the problem also, one related to word indirectly "Affixa" and one not related in any way that I can see "VisiPics". Thru process of elimination, uninstalling, one at a time is the way I found them.
Just today I installed a third party app, and upon restarting saw that the network printer was not on the toolbar. Investigated and word docs "Not Responding" once again, uninstalled app "AnyDVD Convertor Professional Trial" restarted and everything is fine once again.
Might trry this if none of the above will work for you.
    Self Build
    Intel Core 2 Quad Q6600 Kentsfield 2.4 Ghz LGA 775 Quad
    Foxconn P45A-S LGA 775 Intel P45 ATX
    OCZ2VU80016GQ 16GB (4x4GB) DDR2 800Mhz Vista Dual Channel
    2- Sapphire 10022SL Radeon HD 3850 PCI-e in Crossfire mode
    Acer H213H 21.5" Widescreen Full HD 1080P LCD
    2- Seagate ST3160023AS HD 500GB
    2- Seagate ST31000333AS HD 1TB
    1- Seagate ST310005FJA105-RK Freeagent Desk 1TB
    Enermax EG701AX 600W Switching Power Supply
    Lian Li PC-70 Ext/ATX
    Artic Cooling Freezer 7 Pro for Intel CPU
    Intellimouse Optical
    MS Keyboard Pro
    3766.5Kbits 470.8KBytes
    2- Incessa IN-811 removable drive bays and 8- removable drive bay caddies.
