word in vista
N
noaim
did u do an upgrade or did it do a clean install and place ur old windows in
a windows.old directory.
"ren.gallo" <ren.gallo@discussions.microsoft.com> wrote in message
news:EAA12CE0-05B7-4DD8-8FDA-0221DED2F874@microsoft.com...
> where did word go when i upgraded to vista. I can't find it
J
Jupiter Jones [MVP]
Microsoft Word has never been a part of any operating system.
If Microsoft Word was there before you upgraded, it should still be
there.
Look under Start/All Programs/Microsoft
You may need to reinstall Word using the original media.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
A
Adam Albright
On Tue, 24 Jul 2007 19:44:01 -0700, ren.gallo
Word isn't part of Vista. If you purchased it and had it running in XP
or some other version of Windows and you upgraded to Vista and didn't
do a clean install it should still be there. Click Start, type in
'Word' and in a few seconds a link should appear in the list. Once it
does you can pin it to the start menu. Just right click on the Word
icon.
