would some one be kind enough to help me
handsome777
:mad::cry::cool::devil::confused::D:sarc::sleepy:would someone be kind enough to help me go from vista to windows xp professional , please give me the step by step on how to do this, and make it simple and direct so i can follow the stepts one by one,
question i will have to erase vista and then what? hurry please post the instructions please and i will print them and do just as they are directing me to do..thank a half a million.
rive0108
1.Make sure you have the xp drivers for your system for reinstallation, and backup files.
2.Place the xp disk in the optical drive
Restart computer
At prompt, hit any key to boot from disk
follow prompts to install xp
At hard drive partition screen, delete current Vista installation
Format drive, and install
Activate xp, and reinstall device drivers//software.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
Joan Archer
Cross Stitch Queen
question i will have to erase vista and then what? i need help and hurry please send the instructions please and i will print them and do just as they are directing me to do..thank a half a million.
Did the manufacturer of your machine provide the means to downgrade, if not you may not be able to. There might not be the necessary drivers for XP on the machine and you would probably need to purchase a retail disk of XP to use if the manufacturer wont do the downgrade path.
Those are my thoughts the experts may know whether it would be possible or not :huh:
    Windows 10 Home
    HP 8312 (Socket FP4)
    Generic PnP Monitor ([email protected]) 512MB ATI AMD Radeon R5
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
