WSUS failed during uninstall
M
Mrecomm101
I was trying to install Windows Update Services 3.0 SP2 and my server
shutdown unexpectedly. Then, when I tried to uninstall, it failed. Now I can
neither update or uninstall.
Does anyone know how to manually uninstall WSUS 3.0 SP1 and 2?
C
Cliff Galiher - MVP
What errors are you seeing? If the server "shut down" then the uninstall
should've been rolled back.
If, however, the server unexpected lost power or blue-screened without a
proper shutdown, you probably have larger issues and the WSUS issues are
just a symptom. Knowing what is happening in detail would be beneficial in
determing what is happening.
-Cliff
"Mrecomm101" <[email protected]> wrote in message
news:[email protected]
> can
R
Robbin Meng [MSFT]
Hello,
Thanks for your post.
Like Cliff and Larry indicated, we may need further more information such as Event logs or error messages when you install/uninstall WSUS 3.0. If you don't have any previous good
backup to restore, you may try to download and install the Windows Installer CleanUp Utility(http://support.microsoft.com/kb/290301). Then remove the WSUS 3.0 item from the list
of Installed Products.
Hope this helps.
Best regards,
Robbin Meng(MSFT)
Microsoft Online Newsgroup Support
