XP will not boot from Vista boot menu.
B
BCCO1239
I installed Vista b2 (public) as an upgrade from XP, but can't get back into
XP and need to. When I select "Earlier Version of Windows" and hit enter -
the screen goes to black and nothing happens. Any ideas?
C
Charlie Drake
Did you install Vista as an upgrade to XP or a clean install to a new
partition.
Charlie
B
bcco1239
Installed as upgrade.
> partition.
> Charlie
J
Joe727
Then you overwrote XP with Vista.
Joe
"bcco1239" <bcco1239@discussions.microsoft.com> wrote in message
news:38A95DCF-B781-4644-99C2-97FF9F58B084@microsoft.com...
>> > into
>> > enter -
>> partition.
>> Charlie
B
bcco1239
Ouch. That'll leave a mark. Thanks all.
> Joe
> >> > into
> >> > enter -
> >> partition.
> >> Charlie
C
Charlie Drake
Then you reformat your drive, then use the XP backup image you made
before installing Vista to restore XP, or you unplug the HDD you
installed Vista on and plug your original XP HDD back in.
Sorry but it is not possible to undo Vista without reformatting and
re-installing XP, says so on the tin and in numerous posts throughout
this NG, the Windows Vista Download site does say
"DO NOT INSTALL ON A PRODUCTION PC"
Hope you made backups.
Charlie
