z3r010
Staff member
Found this while surfing, it works well with vista x64.
Download here:- Download Yod'm 3D 1.4 - Yod'm 3D is a virtual desktop manager that will bring to your Windows desktop the fashionable cube effect. - Softpedia
Yod'm 3D is a virtual desktop manager with the fashionable effect : the cube
By default, the rotation of the cube is done with the keys CTRL+SHIFT+Arrows :
Hold down CTRL+SHIFT to use the mouse to turn the cube.
- CTRL+SHIFT+Left/Right = Next/prev desktop
- CTRL+SHIFT+Up = Activate and show a "far" view of the current desktop, Left and right to turn the cube
- CTRL+SHIFT+Down = Activate and show a "near" view of the current desktop, Left and right to turn the cube
( The rotation is possible only horizontally )
To move a windows to another desktop :
To change the wallpaper of a desktop :
- Click on the title bar of the window (not maximized if possible), hold down
- Push CTRL+SHIFT to activate the cube, hold down
- When the cube is activated, move the window on left or right
- Release CTRL+SHIFT
Just use Windows !
For each desktop, change the wallpaper using the windows display setting.
Switch to another application :
Click on the Yod'm 3D icon in the taskbar, the list of the windows opened in other desktop appear.
Click on the application to switch to the desktop.
- Operating System
- Windows 11 Workstation
- doofenshmirtz evil incorporated
- Ryzen 9 5950X
- Asus ROG Crosshair VIII Formula
- Corsair Vengeance RGB PRO Black 64GB (4x16GB) 3600MHz AMD Ryzen Tuned DDR4
- Graphics Card(s)
- ASUS AMD Radeon RX 6900 XT 16GB ROG Strix LC OC
- Creative
- 3 x27" Dell U2724D & 1 x 34" Dell U3415W
- Samsung 980 Pro 1TB M.2 2280 PCI-e 4.0 x4 NVMe Solid State
Drive
- PSU
- 1500W ThermalTake Toughpower
- Case
- ThermalTake Level 10 GT
- Cooling
- Enermax Liqtech 240
- Surface Ergonomic.
- Logitech Performance MX
- 350 Mb/s
- Other Info
- WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
- Operating System
- windows 10
- Surface Pro 3
- 1.9GHz Intel Core i5-4300U (dual-core, 3MB cache, up to 2.9GHz with Turbo Boost)
- 4GB
- Intel HD Graphics 4400
- 12" Multi Touch
- 2160 x 144
- 128GB
- Logitech
- yes
- 350 Mb/s
