Additional Clocks
How to Add Additional Time Zone Clocks in Vista
Vista can display up to three clocks: one for the local time, and two for the time in other time zones of your choice. This will show you how to add an additional Time Zone clock.
EXAMPLE 1: Left Click on Time
EXAMPLE 2: Hover Pointer Over Time
1. Left click on Time (clock) on the taskbar and click on Change date and time settings. (See example 1 above)​
A) Go to step 4 below.​
OR
2. Right click on Time on the taskbar and click Adjust Date/Time.​
OR
3. Open the Control Panel (Classic View), and click on the Date and Time icon.​
4. Click on the Additional Clocks tab. (See screenshot below step 8)​
5. Check Show this clock to add a clock.​
NOTE: You can add one or both clocks.
6. Click on the Select time zone drop down arrow and select one from the list you want displayed on this clock.​
7. Enter a display name for this clock.​
NOTE: You can type up to 15 characters.
8. Click on OK.​
Hello Jud, and welcome to Vista Forums.
Could you post a screenshot of what you see instead?
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hello Jud,
See if you may be able to right click on the time clock on the taskbar and click Adjust Date/Time instead, then be able to follow the rest of the tutorial.
Umm, ok Jud. Have you tried the Control Panel option from step 3 as well? Could you post a screenshot of what you see when you click on Date and Time from the Control Panel?
