Command Prompt Window Here
How to Use Open Command Prompt Window Here in Vista
This will show you how to have a command prompt window open at any drive, file, or folder location of your choice in Vista from their context menu. This will make it easier to perform a command task there instead of having to open a command prompt normally and manually type the folder location in it using the CD\ command.
  • This is not a elevated command prompt.
  • This option is not available for the folder tree in the left Navigation Pane Folders section.
EXAMPLE: Open Command Prompt Window Here at C:\Program Files
OPTION ONE
Using Shift + Right Click
NOTE: This is the default method in Vista.
1. Navigate to a folder of your choice in a Windows Explorer window.​
2. Hold down the Shift key and right click on the folder.​
3. Click on Open Command Window Here. (see screenshot below)​
OPTION TWO
Using a Single Right Click Only
NOTE: This will show you how to have Open Command Window Here as soon as you right click on a drive, file, or folder without having to press the Shift key first. You will need to enable this option below first though.
1. To Remove Having to Press Shift
Remove_Shift_Command_Window_Here.reg
download
B) Go to step 3.​
2. To Restore Having to Press Shift
Restore_Shift_Command_Window_Here.reg
download
7. When done, you can delete the downloaded .reg file if you like.​
  • Remove_Shift_Command_Window_Here.reg
  • Restore_Shift_Command_Window_Here.reg
I only get the option when the folder is in the right pane of explorer, but, nice one.
J
    home build
    AMD Phenom II X4 955
    MSI K9N2 SLI platinum
    4gb
    2 Nvidia 9800gt's SLI'd with 660 core clocks, 512mb ddr3 ea.
    runs thru home stereo, 7.1 channel
    22" Samsung
    c: 320gb maxtor, d: 1tb wd, e: 500gb maxtor, g: 500gb hitachi, 2 external 500gb wd's in enclosures
    750w Corsair
    Zalman
Updated 3-31-08 to include Option Two to remove having to press Shift first.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I'm running Vista Ultimate 23 SP1 and I haven't had any luck with this. I import the first file, but I still don't get the "Open ...Here" entry.
Any ideas?
Hello Ckm1956, and welcome to Vista Forums.
Do you get it when you press and hold Shift, then right click on the file, drive, or folder?
I tested the download # 1 again and it seems to work fine for me.
Try running a sfc /scannow command to see if it can find and fix any bad system files that may be the cause. This tutorial will show you how to if needed.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
If it does not help, then merge this reg file below from my system to see if it can help. It is the default settings in the registry for the command file.
** REMOVED ** < Click to download
It is now included in the tutorial download.
SFC didn't find any problems.
Restoring the Registry defaults enabled the Shift-Open Command Here option.
I was then able to use the .reg file to remove the Shift requirement.
Thanks Shawn!
Your welcome ckm1956. I'm happy to hear that it working for you now. Thank you for posting back with your results.
