Full Screen F11 - Enable or Disable Auto-Hide
How to Enable or Disable "Auto-Hide" in Vista and Windows 7 Explorer Full Screen F11 Mode
This will show you how to enable or disable Auto-Hide in Windows Explorer and Internet Explorer while in Full Screen F11 mode.
By default, Auto-Hide is enabled.
Auto-Hide for Windows Explorer and Internet Exlporer works pretty much the same way it does for the taskbar. When in full screen F11 mode, Auto-Hide hides the address bar and toolbar until you move the mouse pointer to the top of the screen. When you do, the address bar and toolbar slides open.
EXAMPLE: Internet Explorer Full Screen F11 with Auto-Hide Enabled
NOTE:
Notice the address bar and toolbar are hidden while in full screen mode with Auto-Hide enabled.
EXAMPLE: Internet Explorer Full Screen F11 with Auto-Hide Disabled
1. Open a Windows Explorer or Internet Explorer window.​
2. Press F11 to turn full screen mode on or off.​
NOTE: On laptops or some multimedia keyboards, you may need to press the F Lock (Function) key or press and hold the Fn key and the F11 together instead of just F11.​
3. Right click on the area boxed in red in the upper right corner of the Windows Explorer or Internet Explorer window. (See screenshots below)​
NOTE: The left screenshot is in IE8 , and the right screenshot is in Windows Explorer. In IE9, right click on a empty area on the tab bar.​
4. To Enable Auto-Hide
NOTE: This will enable Auto-Hide in both Internet Explorer and Windows Explorer when changed in either one.​
A) Click on Auto-Hide to check it. (See screenshot below step 5)​
5. To Disable Auto-Hide
NOTE: This will disable Auto-Hide in both Internet Explorer and Windows Explorer when changed in either one.​
A) Click on Auto-Hide to uncheck it. (See screenshot below)​
...just wanted to say thanks after searching around to solve my problem and finding nothing exactly relevant except this post... which hit it right on the button! Now my toolbars and command menus autohide like they used to under XP.. and my screen real-estate is once again maximized! :cool:
You're most welcome Gilamon, and welcome to Vista Forums. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
that is exactly what I was looking for. What originaly happened was my cockatiel ran across the key board and enabled it and also disabled it so I could not figure out what happened. I have been to two Geek Squads with no results. Again Thanks.
You're most welcome Al, and welcome to Vista Forums. :)
Hello Shawn, good tutorial thank you I have already put it to use.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    HP Multimedia Keyboard
    Microsoft Wireless Mouse 5000
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
Thank you Tom. :)
