SP1 Disk Cleanup Tool
How to Use the Vista SP1 Disk Cleanup Tool
This will show you how to run the Vista SP1 Cleanup tool to permanently remove the Vista RTM backed up files created during the installion of the Vista SP1 to gain more hard drive space.
Running the Windows Vista Service Pack 1 Disk Clean-up tool permanently removes the ability to uninstall the Vista SP1. Do not run this tool unless you have no plans of uninstalling the Vista SP1 and just want to save or regain hard drive space. The only option to remove the SP1 after using this tool is to do a clean install of Vista.
The Vista SP1 disk cleanup tool gave me back 1.6 GB on my hard drive. This amount will vary on each computer. To see how much space you recover, make a note of how much free space you have on the C:/ drive in Computer before and after you run the SP1 Cleanup Tool.
NOTE:
If you installed Vista SP2, then you will need to use the Vista SP2 Disk Cleanup tool instead. The SP1 Disk Cleanup tool will no longer work after installing SP2.
2. In the elevated command prompt, type vsp1cln.exe and then press Enter. (See screenshot below)​
3. Type Y when you see Would you like to continue? and press Enter.​
NOTE: Tying N will cancel running the Vista SP1 disk cleanup tool. You can also just close the command prompt window to cancel to.​
4. It will take a little bit to finish. When it is finished, you will see the Windows Vista Service Pack 1 Disk Clean-up completed message. (See screenshot above)​
5. When it's done, you can close the elevated command prompt.​
I tried to uninstall sp1, which it would not. Read on a page somewhere that it contains a kernel update is why it wouldn't? Then again, I have no need to uninstall it, but I dislike junk/clutter on any of my HD's, so thank you.
Jerry
    home build
    AMD Phenom II X4 955
    MSI K9N2 SLI platinum
    4gb
    2 Nvidia 9800gt's SLI'd with 660 core clocks, 512mb ddr3 ea.
    runs thru home stereo, 7.1 channel
    22" Samsung
    c: 320gb maxtor, d: 1tb wd, e: 500gb maxtor, g: 500gb hitachi, 2 external 500gb wd's in enclosures
    750w Corsair
    Zalman
You're welcome Jerry. I hate wasting space to. Especially when it is over 1 GB.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi Shawn
Thanks for that mate.
Tell me, is there a similar procedure for deleting all the backup files that accumulate from installing Hotfixes, Security Updates etc. through Windows Update? Please advise.
Regards
Neil
    Intel Core i7-920
    Gigabyte GA-EX58-UD3R
    Gigabyte GV-N26OC-896H-B
    N/A - On Board via SPDIF
    BenQ 24" E2420HD
    1920 x 1080p Full HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
    Antec Twelve Hundred
    2 x Liteon DVD Burners Sata
Sorry Neil, but all I can find is how to remove the Windows Update backup files in XP and not in Vista. It will not work for Vista. :(
Thanks for checking it out Shawn. I'll try to find out from TuneUp Software and if I get anywhere I'll let everyone know. I know when I ran their cleanup utility previously it deleted something like 3,500 backup files.
Neil
    Intel Core i7-920
    BenQ 24" E2420HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
You're welcome Steve, that's great to hear.
I'm getting jealous. Everyone is reporting that they are gettin more space recovered than I did. I even had someone report that they got nearly 9 GB recovered. :shock: Maybe I just keep a cleaner house. LOL ;) Yeah, that's it. :o
LOL Steve. Could be. I'm always deleting things. ;)
Thanks for the tutorial. Cleared about 2.5gb for me. :)
Kyle
    Intel Core2 Duo E6750
    Gigabyte GA-P35-DS3L v2.0
    2gb G.Skill DDR2 800
    GeForce 8800GT 512MB
    Samsung HD160JJ
You're welcome Kyle. Nice amount cleaned.
Thanks once again Shawn. If my math is correct approx. 1.9 GB free space now :party:
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main
    500 GB USB External
    160 GB USB External
    2TB USB External
    DSL 3MB
You're welcome Joe. Not a bad amount.
Hi Drewbot,
That's strange. What type of Vista do you have installed, retail or OEM?
Did you have any problems installing the SP1?
Anything installed that may be blocking the cleaner from running?
I have Vista Home Premium x86 pre-installed on my Dell laptop. I had no problems installing SP1 via Windows Update when it was released. I can't think of anything that may be preventing the clean-up tool from working...
Drewbot,
I'm not sure why it will not clean the SP1 backups. I ran it on my system again to check if that was it, after I already cleaned them, and it still ran. It just finished really fast since there was nothing there to clean.
You might try booting into Safe Mode and try running this in there. If something is blocking it, it should run in Safe Mode.
Hmmm... I must really keep mine clean.. I don't believe I got much of any space reclaimed after running this..~ :)
    Athlon 3700+ 2.2
    Abit AN8 32x
    3gig
    Dual SLI GForce 6800 GS
    2 SATA 320 gig Barracuda drives running XP Pro and Vista Ultimate each on its own drive
