Bypass UAC
Bypass UAC for Standard Users
This guide will help setup a Desktop Shortcut for Bypassing UAC for programs that require UAC Administrative Permissions and allow Standard Users to run these programs without Administrative Access using a known bypass trick in Task Manager and a Desktop Shortcut,
You can also use this trick to launch the program via command prompt or from scripts.
Step 1
Open the Start-Menu and typeTask Scheduler then run it​
Step 2
You will now see the Task Scheduler Management Console , To the right click Create Task
Step 3
A new window to create tasks will appear, Type a Name and Description of the task and then Tick “Run With Highest Privileges” towards the bottom. (Don’t Change any other settings)
NOTE: Remember the name you called this Task as you will need it later.
Step 4
If you created the task under say the "Microsoft" folder the task name changes to C:\Windows\System32\schtasks.exe /run /tn "\Microsoft\taskname"...You can find out where it was registered by going to the history tab in Task scheduler..
Are you signed in as administrator?
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
When i do this it wants me to enter my password then says i don't have the privileges. Why?
Hi Sonic,
Just make sure you specify the account username and password at step3 for the administrator account the task needs to runas and make sure you also tick "Run with Highest Privileges" ;)
Locoeng,
You dont need to be signed in as administrator, you only need to make sure the account specifyed to run the task is an adminisrator ;)
Steven
Thanks for the clarification Steven :)
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    1440X900
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
After step 7, I go to press okay and it says "Enter user account information for running this task." it comes up with the user dell\(yournamehere) and asks for a password.
I gave it my password for my standard user account on the computer, but it says, "Task Scheduler cannot create the task. The user account is unknown, the password is incorrect, or the user account does not have permission to create this task."
I assume that means that standard users are not allowed to create the task outlined here... is there anything I can do to still bypass UAC? It does come very often, and it is annoying. Vista security seems to have just become so much more intense and uptight, I'm not even sure I can bypass this at all. Well, not easily at least.
Help please?
Hello Anika, an welcome to Vista Forums.
I'm sorry, but yes you need to be an administrator to be able to create this task for Standard accounts. :(
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi
im running as admin but when UAC on Host man(hostmanager) program don't start automatically it needs admin permission or i need to run as admin all the time after reboot.If im not home this very big issue if my hostfile is not running ..thats why i disabled UAC ..but if i do this way(tutorial) this gonna solve this problem..i mean if i enable UAC again and after all reboot Hostman will run automatically???
Any advice
regards
ok i need help i got to end of step 7 then when i clicked ok and it wanted me to enter user account information for running this task. any help?
Hello Irukashi, and welcome to Vista Forums.
You cannot. You must be logged into a administrator account to be able to do this. :(
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
Brink, an expert (who I basically took his word on,) once told me to never disable UAC, as it's the "frontline of defense for Vista." As I understood it, any sort of intrusion, say from the outside or someone remoting-in (sorry, trite example, but best I can do,) would be stopped by UAC.
Since then, I haven't really found reason to doubt it. I've been pretty educated and self-studied; moreover, crash-course-educated on A/V, A/M/ Anti-Spyware, etc. software.
Is it (Windows 7, Vista x64, whatever,) seen, generally, as a nuisance?
I have read this before and haven't seen a true concensus.
Thanks.
v877051
    Dell
    Intel Core i7 820QM 1.73GHz "Clarksfield" (8 Threads)
    Dell Inc. 0874P6 (U2E1)
    4.0GB Dual-Channel DDR3 @ 661MHz (9-9-9-24)
    ATI Mobility Radeon HD 5400 Series
    (SoundMAX) IDT High Definition Audio
    15"+ Standard Dell Studio 1558 LCD monitor.
    1024 x 768
    (x2) 1TB WD "Elements" External HDD + (x1) 1.5TB WD "Elements) External HDD; 500GB Solid State Storage on laptop.
    N/A Notebook
    N/A
    External (NON-USB!) NZXT CRYO-S (X) Silver. ICE COLD.
    Standard, non-10-key, no fancy backlighting.
    Good 'ol reliable USB 2.0 Microsoft 3-button mouse.
    16 Mbps w/ Aaris DOCSIS 3.0-compliant modem
    Gigabit LAN. Tight network security. (Hopes of getting a Linksys 4-Port Gigabit Security Router with VPN!) Disabled WiFi/Wireless hardware; don't believe in the concept. If I did, would use draft-N adapter.
