Sleep Return Timeout for Unattended Wake Up
  1.    14 Jan 2011 #10
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 08:49
    usa us oklahoma
      Thread Starter
    Re: Sleep Return Timeout for Unattended Wake Up
    Quote Originally Posted by darthmowzy View Post
    This unattended wake sleep timeout is part of windows 7 also unfortunately. If I turn my computer on from sleep and walk away without moving the mouse my computer should not go to sleep after 2 minutes.
    I delete this regedit key and now my computer doesnt auto sleep
    Code:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\238C9FA8-0AAD-41ED-83F4-97BE242C8F20\7bc4a2f9-d8fc-4469-b07b-33eb785aaca0\DefaultPowerSchemeValues
    Hello Darth, and welcome to Vista Forums.
    That's a bit drastic to delete your power plans, when you probably could have changed the power plan settings to never Sleep instead. However, as long as it works and your happy with it though.
  2.    15 Jan 2011 #11
    windows 7 64bit, Ubuntu 10.10 64bit, Windows_3.1_loljk
    Local Time: 07:49
    I deleted the setting not the profile. Ive looked for another way to eliminate auto sleep after unattended wake but I haven't found one.
  3.    15 Jan 2011 #12
    Texas, USA
    Local Time: 08:49
    usa us oklahoma
      Thread Starter
    Other than what you did, the usual way was to set a high enough wait time that you would be active on the computer before it reaches thatm to effectively be the same as disabling it.
    Thank you for sharing it.
Page 2 of 2 FirstFirst 12
My PC gets BLACK SCREEN after unattended wake up from sleep mode
Hello all, I've scheduled my PC to wake up at a certain time with vista's task scheduler, and when it wakes up, I always see black screen on my...
General Discussion
Return from Sleep with no usb mouse or keyboard
Everytime I return from Sleep mode there is no response from my mouse or keyboard and I have a black screen even tho my unusable mouse cursor is on...
General Discussion
Computer won't go to sleep after timeout
I've gone thru this tutorial, but have not had luck. My Vista Ultimate 32-bit had been working fine the last month. Then out of the blue, it just...
General Discussion
Return from Sleep/Lock problem
Vista, SP1 I have an issue returning from sleep mode or simply "lock workstation" mode. It works fine if I sleep/lock and return within a few...
Vista General
Shutdown on return from sleep
When I put my laptop into sleep mode it works fine. Trying to return from sleep mode it instantly shuts down on me. Anyone have any ideas what I...
Vista General
Return from sleep mode is strange
I have had my Samsung Q35 and Microsoft Vista package now for about 9 months, but recently have started experiencing a strange problem. Every time I...
Vista performance & maintenance
Return Stream Timeout
Can i return a Stream without know Timeout? My service use Streamed TransportMode and a Per-Call session. Actually, while my Client read from...
Indigo
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
