BootMGR Compressed Message at Boot Fix
How to Fix the BootMGR is Compressed Message at Boot
Why does this BootMGR is Compressed message appears at boot?
Well, for some bizzare reason, Vista also compresses the BOOTMGR when you select (check) to Compress this drive to save data space option on the C: drive. When BootMGR is compressed Vista cannot boot from it. This will show you how to fix this boot error.
1. First of all, boot from your retail Vista or Windows 7 installation DVD, or from you bootable Vista USB or Windows 7 USB installation thumb key. ( By pressing Esc and f8 )​
NOTE: If you do not have a retail installation disc, then you can create a Vista recovery disc or Windows 7 system repair disc to use to do the steps below with instead.​
2. Now you wait while it is loading the files.​
NOTE: If it says BootMGR is compressed while booting Windows Vista CD, then go to BIOS, (Normally by pressing f12), load manufactory defaults, and change the Boot Priority, so that the Hard Drive is the first to be loaded.
3. When you boot on Windows 7/Vista DVD/USB, select Repair your computer.​
4. Select your OS, and click on LOAD DRIVES.​
5. A box should now appear. Click on Yes.​
6. After that, navigate back to the local drive C: , and right click on it and click on Properties and the Advanced tab.​
7. UNCHECK the Compress this Drive To Save Space option, then repeat this again.​
8. Do step 6 and 7 for the local drive "X" as well, UNCHECK if it is Checked.​
9. Now you double click on the local drive C: , and see if there is anything named with Blue text.​
10. If there is, then repeat step 7.​
NOTE: After you've done that, you can normally Re-Boot your Computer, and there you go, it is Done. Problem Solved.​
Hi AlexRD,
Can you please explain how can we open the Computer or how were you able to navigate to Local Disk C? Is it thru command prompt?
Because after clicking on Repair Your Computer, i get these 5 options,
Startup Repair, System restore, windows memory diags, command prompt and Windows Complete PC restore...
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hi AlexRD,
Well, you shouldn't choose the Operating System.
You know that option, LOAD DRIVES, when vista is finding which OS is installed in your computer? That option you should use, load drives, and after that it is going to come a box for you to explore. Then you follow those Steps.
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    Asus G2s Keyboard from Logitech
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    2 MB Wireless Network
Gotcha.
    Compaq
    15"
    160 GB WDC
I want to say this method does work I learned the hard way by compressing my drive and then being unable to log back in because i would get this message... so dont compress your drive you will get this message as well or atleast thats when I got the message.
Hi AlexRD,
Hi AlexRD & dinesh
This may be of help.
Copy & Paste in Windows Recovery Console.
Copy & Paste - in Windows Recovery Console - Windows 7 Forums
I am frustrated as all get out because I have the BOOTMGR is compressed error and all I can find for a solution is to use the installation or recover disks. Well I don't have any. The computer (Lenovo X41) came without an optical drive. I bought it used and the seller did not have any installation disks or recovery disks (which would have been useless anyway without an optical drive.)
So how can I fix this without any disks??????????????????????
Download and burn a completely legal recovery CD from here: Windows Vista Recovery Disc Download — The NeoSmart Files
It is a torrent file, so if you have any problems with any of it, don't hesitate to ask!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Perhaps you missed the part about there being NO OPTICAL DRIVE on this laptop. Although havinng a recover disk is good, even if I had one, I could not use it. The frustrating thing is not finding any solution that does not involve using a disk.:huh:
Ooops! Maybe I didn't read quite carefully enough! Sorry!
Download the file, open the .iso, and copy every single file inside it onto a USB memory stick. Keep the USB memory stick empty of everything else (ie backup your current USB files, and then delete them all from the USB stick) then switch the computer on. Go into the one time boot menu, and select the option which contains the letters USB. In theory at least this should work, but USB always seems to be a slightly iffier proposition. Any problems, don't hesitate to ask!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I got stuck on step 6, when i click right on drive c, and choose properties, i didn't see advance tab
i also can't see advance tab in drive x.
and in this one, does it means i use wrong window for my computer?
From your first screenshot uncheck compress disk drive.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
