Select all - Add to Context Menu in Vista
How to Add "Select all" to Context Menu in Vista
By default in Vista, you have to either click on Edit (Menu bar) and Select all or press CTRL+A to select all items in a Windows Explorer window.
This will show you how to add Select all to the context menu of the desktop and blank area in a folder window for all users to be able to easily select all items in a Windows Explorer window in Vista.
While you must be logged in as an administrator to add or remove the context menu, all users will be able to use the context menu.
EXAMPLE: "Select all" added to context menu
NOTE:
You would right click on a empty area on the desktop and in a folder window to see these.
OPTION ONE
To Add "Select all" to Context Menu
1. Click on the Download button below to download the .zip file below, and save it to your desktop.​
Add_Select_all.zip
download
2. Unblock the .zip file.​
3. Open the .zip file, and extract (drag and drop) the Add_Select_all.reg and selectall.vbs files to your desktop.​
4. Move the selectall.vbs file into your C:\Windows folder. If prompted, click on Continue to approve.​
5. Double click on the Add_Select_all.reg file to merge it.​
6. If prompted, click on Run, Continue (UAC), Yes, and OK to approve the merge.​
7. Select all has now been added to the context menu in Vista.​
8. If you like, you can now delete the downloaded files.​
OPTION TWO
To Remove "Select all" from Context Menu
NOTE: This is the default setting.
1. Click on the Download button below to download the .reg file below, and save it to your desktop.​
Remove_Select_all.reg
download
2. Double click on the downloaded .reg file to merge it.​
3. If prompted, click on Run, Continue (UAC), Yes, and OK.​
4. Open the C:\Windows folder, and delete the selectall.vbs file.​
5. Select all has now been removed from the context menu in Vista.​
6. If you like, you can now delete the downloaded .reg file.​
  • Add_Select_all.zip
  • Remove_Select_all.reg
Thanks for this. I thought it looked like a good idea so I installed the .reg file and "Select all" was added to the context menu. Clicked an empty area in the window and tried it but got the following error:
"Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item."
Select all still works with Ctrl + A and from the Edit menu. Any idea why it won't work? I have full permissions on the folder in question.
Vista Home Basic 32 bit
Hello Walt,
Does "Select all" work properly for you for other locations, and does it only happen for this one folder?
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi Brink, thanks for your reply.
I found another site that has a similar reg edit and it's working for me.
** REMOVED **
It has a .vbs file you add to C:\Windows. The .reg file also looks different from yours. Not really sure why one works and the other doesn't. I'm pretty sure I didn't try yours on any other folders.
The tutorial is working just fine for me, so I'm not sure why it's not for you. :huh:
The differences is that there option uses a .vbs file to select all using send key, while mine uses the native select all command.
Tutorial updated back to the original method to work better.
