Shell Command
  1.    28 Dec 2009 #10
    vista home premium
    Local Time: 06:18
    Re: Shell Command
    Hi Brink,
    Thanx for your quick reply. my laptop is just 2 months old. just bought it here on aruba. everything else works fine, but i do have a problem with the memory vista eats (use hihi)
    The game im trying to unpack and install is anno 1404, i already have anno 1701 the pre version and that one worked correct.
    This one has files named rzr.001 etc. So i need to unpack it and then install. But it does not work. Vista does not wanto unpack it. It just says nothing and do nothing.
    So i looked at the properties of the files, and it said i need Windows blabla commor, so started to search for it and came here.
    i tried your commands and just like i said it says: cant find file, i started to try the others and got the same or does not exicst etc.
    I tried with winrar, winzip etc, did not work, it will pack but not unpack proper. I am going to try your advice with the 7 program you just said and will come back on that.
    I also found out that it is form razor, so i found razor program but im not familiair with it. beside that i red some comments and a lot say it does not work. or have errors.
    im realy carefull with downloading things. so im going to try 7 zip and see what happens
    tahnx i will get back to you
  2.    28 Dec 2009 #11
    vista home premium
    Local Time: 06:18
    Re: Shell Command
    hi brink,
    Again thank you. I tried 7 zip, good program and the program told me that when he finished at 97% teh file is dameged. So i need to download i new versie of teh game. this was the only program tha regonized it.
    Thanx i will try to download a new one and see what happens.
    kind regards,
    natasja
  3.    28 Dec 2009 #12
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 07:18
    usa us oklahoma
      Thread Starter
    Re: Shell Command
    Oh, I see now. You are wanting to unpack an archive. If WinRAR or 7-Zip cannot unpack it using the "Wizard" option, then you might try redownloading the file in case it may be corrupted.
  4.    12 Dec 2010 #13
    Laytonsville, Maryland, USA
    Vista Business 32bit SP2 (build 6002)
    Local Time: 07:18
    usa us maryland
    Re: Shell Command
    Hi Brink,
    I have an OP who somehow changed the name displayed in the Folder View of Windows Explorer AND the system desktop icon for the User Folder from the correct user name to something different and I cannot find any way to change either of them to what they should be again (System Restore didn't work and that folder and icon have no options to rename or do anything - and no, I have no idea how it was done in the first place and neither does the OP, but apparently he got mixed up with some changes to the desktop and began pushing buttons without really thinking and before he knew it this had happened).
    I was reading this tutorial and saw shell:UsersFilesFolder and it seemed to be what is needed to fix that folder and that icon, but I can't figure out how to do it. I wondered if there was any way to apply this to those incorrectly-named locations to restore them to the proper names - or if there is another tutorial I missed that actually addresses this problem.
    As always, thanks for your assistance.
  5.    12 Dec 2010 #14
    Texas, USA
    Local Time: 07:18
    usa us oklahoma
      Thread Starter
    Re: Shell Command
    Hi Lorien,
    shell:UsersFilesFolder will not fix it, but only open that location instead.
  6.    12 Dec 2010 #15
    Local Time: 07:18
    usa us maryland
    Re: Shell Command
    Thanks, Brink.
    I was afraid that might be the case - and I guess that also means there isn't another tutorial on how to do it. Oh well, back to the research. There must be some way to do it - after all, he was able to change it to the wrong thing somehow so a method of changing to the right thing MUST exist.
    Thanks again.
  7.    12 Dec 2010 #16
    Texas, USA
    Local Time: 07:18
    usa us oklahoma
      Thread Starter
    Re: Shell Command
    I would say to just create a new acount and use it instead.
Page 2 of 2 FirstFirst 12
Shell Command
Executing secondary command in shell.run
Hello I want to run some commands consecutively with shell. See below, set shell=createObject("wscript.shell") set...
VB Script
WScript.Shell echo command?
I'm trying to run a program within vbs using WScript.Shell that requires a pipe. The command i need to run is echo <text> | clip But when i...
VB Script
Exchange Management Shell Command from vbscript
hi, How do I start an EMSC (Exchange Management Shell Command) from a vbscript? I've tried something like this: oShell.Run "PowerShell.exe...
PowerShell
Re: Have a command shell open but hidden
Hello, You can use the task scheduler (click start, type task scheduler, press enter, click create task on the right). If you select the...
Vista General
Question about Launching shell command from Credential Provider
We need to launch our applicatoin from the IConnectableCredentialProviderCredential::Connect(). I have following questions: 1. In the FAQ of...
Vista General
Wrap command shell in System.Diagnostics.Process
Does anyone know why using System.Diagnostics.Process to "wrap" a console application does not always transmit the I/O, depending on what processes...
PowerShell
Drag and Drop from explorer into command shell
You used to be able to drag a file or folder from the explorer into the command shell where it would show up as a path. That made it easy to run...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
