PC Freezing and ctrl alt del not working, etc........
I have Vista on Inspiron 530 desktop. The PC is OK for about an hour then
internet gets very slow, finally freezing. When I press ctrl alt del I get
message "Logon process has failed to create the security options dialog" and
below this "Failure - security options" . The only way out of this is to turn
off the electricity to the pc.
Even if I don't get this error, I am seldom able to "shut down" the
computer. I sometimes get the "logging off" message which changes to
"shutting down" but even after waiting ages, it does not usually shut down so
I just have to switch it off.
I have scanned thoroughly for viruses but have not found any and have virus
and firewall programs running at all times.
Re: PC Freezing and ctrl alt del not working, etc........
More than likely this happens because you have a non-Vista compatible
security suite installed. Have you installed some kind of
firewall/antivirus/whatever suite? If so, which?
Your question may already be answered in Windows Vista Security: http://www.amazon.com/gp/product/047...otectyourwi-20
"wendykf" <wendykf@xxxxxx> wrote in message
news:EBF257F7-2CAC-4AAE-A9F8-03DD3A1FF732@xxxxxx
> and
> turn
> so
> virus
> Any help or ideas would be gratefully received
System Manufacturer/Model Number Self Built OS Windows 7 home premium 64 bit CPU I5 3570K Motherboard Gigabyte Z77-DS3H Memory 4 x 4GB corsair ballistix sport DDR3 1600 Mhz Graphics Card Gigabyte Geforce GTX 660 TI Sound Card creative x-fi Monitor(s) Displays Primary CiBox 22" Widescreen LCD ,Secondary Dell 22" Widescreen Screen Resolution Both 1680 x 1050
Keyboard Logik Mouse Technika TKOPTM2 PSU Corsair HX 620W ATX2.2 Modular SLI Complient PSU Case Antec 900 Ultimate Gaming Case Cooling 3 x 80mm tri led front, 120mm side 120mm back, 200mm top Hard Drives 2 x 500G HD (SATA) 1 x 2TB USB Internet Speed 288 / 4000 Other Info Creative Inspire 7.1 T7900 Speakers
Trust Graphics Tablet
I have exactly this same problem. Computer slows to a crawl. control Atl
delete yields failure - security options logon process has failed to create
the seciryt options dialog
Have run complete checkdisk and hard drive tests and everything comes up okay
Anyone at Microsoft have an idea?
> > Hi Thanks for your reply. Just looked at the events log and the last entry is
> > for 7 Dec but I have been having the same problem every day since then - or
> > should I be doing something to initiate it?
> > "Bob" wrote:
> > > Wendy,
> > > Can you check the event log and post any errors for ACPI, DCOM, NTPCLIENT
> > > and/or Service Control Manager?
> > > It would be helpful if you could do this immediately after a restart and
> > > before opening any other applications except those which are set to
> > > autostart.
> > > newsECED89A-9A93-41E1-BF1D-A3DD90480A35@xxxxxx
> > > > Thanks
> > > > No that is not the problem. I was only running AVG when the problem
> > > > occurred. I then ran Avast to see if AVG had missed something.
> > > > Often, I am not running programs other than those at Start up but browsing
> > > > the internet and email, leaving the computer idle for much of the time but
> > > > it
> > > > still freezes.
> > > > "Ken Blake, MVP" wrote:
> > > >> On Thu, 3 Jan 2008 05:23:01 -0800, wendykf
> > > >> > I have Zone Alarm and AVG and recently (with no change to the problem)
> > > >> > Avast. As far as I know these are all compatable with Vista
> > > >> Are you running AVG *and* Avast--two anti-virus programs--at the same
> > > >> time? That's a prescription for disaster. They will conflict with each
> > > >> other, and that is likely the cause of your problem.
> > > >> Choose one (I prefer Avast) and get rid of the other and see if that
> > > >> doesn't solve your problem.
> > > >> > > >then
> > > >> > > > del I get
> > > >> > > > dialog"
> > > >> > > > and
> > > >> > > > is to
> > > >> > > > turn
> > > >> > > > to
> > > >> > > > shut down
> > > >> > > > so
> > > >> > > > have
> > > >> > > > virus
> > > >> Ken Blake, Microsoft MVP Windows - Shell/User
> > > >> Please Reply to the Newsgroup
I have now solved the problem by reformating the disk to ex-factory condition
(after saving files I wanted, of course). This was drastic but very glad I
did it. I think my problems arose because I imported files and settings from
my old computer and probably introduced the problem to my new computer. In
taking the easy option, as I thought at the time, I imported many things that
I didn't really need any more. Hope you sort your problem soon, I know how
frustrating it is.
> > > "Bob" wrote:
> > > > Wendy,
> > > > autostart.
> > > > > Thanks
> > > > > it
> > > > > still freezes.
> > > > >> > > >then
> > > > >> > > > del I get
> > > > >> > > > dialog"
> > > > >> > > > and
> > > > >> > > > is to
> > > > >> > > > turn
> > > > >> > > > to
> > > > >> > > > shut down
> > > > >> > > > so
> > > > >> > > > have
> > > > >> > > > virus
Thanks for responding. My computer was a new vista machine to which no
setting were transferred. It worked fine for nearly a year. Now it's
basically useless. Programs simply will not load, a different one on a daily
basis.
> frustrating it is.
> > "wendykf" wrote:
> > > Just found these (not really sure what I am doing as you may guess) . These
> > > were some errors in today's logs under System and applications. I have pasted
> > > info below - hope it is what you need.
> > > Thanks again
> > > Under System
> > > Error 04/01/2008 12:35:04 Service Control Manager Eventlog Provider 7001 None
> > > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
> > > - <System>
> > > <Provider Name="Service Control Manager"
> > > Guid="{555908D1-A6D7-4695-8E1E-26931D2012F4}" EventSourceName="Service
> > > Control Manager" />
> > > <EventID Qualifiers="49152">7001</EventID>
> > > <Version>0</Version>
> > > <Level>2</Level>
> > > <Task>0</Task>
> > > <Opcode>0</Opcode>
> > > <Keywords>0x80000000000000</Keywords>
> > > <TimeCreated SystemTime="2008-01-04T11:35:04.000Z" />
> > > <EventRecordID>38680</EventRecordID>
> > > <Correlation />
> > > <Execution ProcessID="0" ThreadID="0" />
> > > <Channel>System</Channel>
> > > <Computer>Wendy-PC</Computer>
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data Name="param1">Computer Browser</Data>
> > > <Data Name="param2">Server</Data>
> > > <Data Name="param3">%%1068</Data>
> > > </EventData>
> > > </Event>
> > > Error 04/01/2008 12:38:25 DistributedCOM 10005 None
> > > - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
> > > - <System>
> > > <Provider Name="Microsoft-Windows-DistributedCOM"
> > > Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
> > > <EventID Qualifiers="49152">10005</EventID>
> > > <Level>2</Level>
> > > <Task>0</Task>
> > > <Opcode>0</Opcode>
> > > <TimeCreated SystemTime="2008-01-04T11:38:25.000Z" />
> > > <EventRecordID>38690</EventRecordID>
> > > <Correlation />
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data Name="param1">1084</Data>
> > > <Data Name="param2">usnjsvc</Data>
> > > <Data Name="param3" />
> > > <Data Name="param4">{98AC5C33-EE18-4EC2-BE25-3B16EE8F75F1}</Data>
> > > </EventData>
> > > </Event>
> > > Error 04/01/2008 15:20:40 DistributedCOM 10005 None
> > > - <System>
> > > <Level>2</Level>
> > > <Task>0</Task>
> > > <Opcode>0</Opcode>
> > > <TimeCreated SystemTime="2008-01-04T14:20:40.000Z" />
> > > <EventRecordID>38692</EventRecordID>
> > > <Correlation />
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data Name="param2">WSearch</Data>
> > > <Data Name="param4">{9E175B68-F52A-11D8-B9A5-505054503030}</Data>
> > > </EventData>
> > > </Event>
> > > and these under Application
> > > Error 04/01/2008 11:06:32 WerSvc 5007 None
> > > - <System>
> > > <Provider Name="WerSvc" />
> > > <EventID Qualifiers="49152">5007</EventID>
> > > <Level>2</Level>
> > > <Task>0</Task>
> > > <TimeCreated SystemTime="2008-01-04T10:06:32.000Z" />
> > > <EventRecordID>22610</EventRecordID>
> > > <Channel>Application</Channel>
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data>8014FFF9</Data>
> > > </EventData>
> > > </Event>
> > > Error 04/01/2008 12:18:32 EventSystem 4621 Event System
> > > - <System>
> > > <Provider Name="Microsoft-Windows-EventSystem"
> > > Guid="{899daace-4868-4295-afcd-9eb8fb497561}" EventSourceName="EventSystem"
> > > <EventID Qualifiers="49152">4621</EventID>
> > > <Level>2</Level>
> > > <Task>16</Task>
> > > <Opcode>0</Opcode>
> > > <TimeCreated SystemTime="2008-01-04T11:18:32.000Z" />
> > > <EventRecordID>22623</EventRecordID>
> > > <Correlation />
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data Name="param1">80070005</Data>
> > > <Data Name="param2">EventSystem.EventSubscription</Data>
> > > <Data
> > > Name="param3">{CEB8B221-89C5-41A8-98CE-79B413BF150B}-{00000000-0000-0000-0000-000000000000}-{00000000-0000-0000-0000-000000000000}</Data>
> > > </EventData>
> > > </Event>
> > > Error 04/01/2008 12:34:30 EventSystem 4609 Event System
> > > - <System>
> > > <EventID Qualifiers="49152">4609</EventID>
> > > <Level>2</Level>
> > > <Task>16</Task>
> > > <Opcode>0</Opcode>
> > > <TimeCreated SystemTime="2008-01-04T11:34:30.000Z" />
> > > <EventRecordID>22646</EventRecordID>
> > > <Correlation />
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data
> > > Name="param1">d:\vistartm\com\complus\src\events\tier1\eventsystemobj.cpp</Data>
> > > <Data Name="param2">45</Data>
> > > <Data Name="param3">8007043c</Data>
> > > </EventData>
> > > </Event>
> > > and
> > > Error 04/01/2008 12:38:19 EventSystem 4609 Event System
> > > - <System>
> > > <Level>2</Level>
> > > <Task>16</Task>
> > > <Opcode>0</Opcode>
> > > <TimeCreated SystemTime="2008-01-04T11:38:19.000Z" />
> > > <EventRecordID>22647</EventRecordID>
> > > <Correlation />
> > > <Security />
> > > </System>
> > > - <EventData>
> > > <Data
> > > </EventData>
> > > </Event>
> > > > "Bob" wrote:
> > > > > Wendy,
> > > > > autostart.
> > > > > > Thanks
> > > > > > it
> > > > > > still freezes.
> > > > > >> > > >then
> > > > > >> > > > del I get
> > > > > >> > > > dialog"
> > > > > >> > > > and
> > > > > >> > > > is to
> > > > > >> > > > turn
> > > > > >> > > > to
> > > > > >> > > > shut down
> > > > > >> > > > so
> basis.
> > (after saving files I wanted, of course). This was drastic but very gladI
> > taking the easy option, as I thought at the time, I imported many thingsthat
> > frustrating it is.
> > > "wendykf" wrote:
> > > > Just found these (not really sure what I am doing as you may guess) .. These
> > > > Thanks again
> > > > > "Bob" wrote:
> > > > > > Wendy,
> > > > > > before opening any other applications except those which are setto
> > > > > > autostart.
> > > > > > "wendykf" <wend...@xxxxxx> wrote in message
> > > > > > > Thanks
> > > > > > > it
> > > > > > > still freezes.
> read more »- Hide quoted text -
> - Show quoted text -
It appears to be "solved" by disabling Windows Aero even though it had
worked for the first 8 months of the computer's life. Any thoughts
about why that would fix it?
CTRL+C not working CTRL+C does not always work for me. I actually have to go to Edit and select
Copy. It drives me crazy.
I am on XP SP3.
Live Mail
Ctrl + P not working in 2007 When i press Ctrl+ P to print instead of the print menu i get a Macro error - I have tried with Macros Enabled but still same error - Any advice is...
Software
Copy (Ctrl+C) and Paste (Ctrl+V) not working Having problems with Copy (Ctrl+C) and Paste (Ctrl+V) in Windows Live Mail
-- they don't work. The only bypass I know of is to use F3 to look...
