1.    25 Aug 2008 #1
    Vista Home Premium 32bit
    Local Time: 04:41
    Blue Screen Problem
    Files that help describe the problem:
    C:\WINDOWS\Minidump\Mini082608-01.dmp
    C:\Users\Hp\AppData\Local\Temp\WER-104099-0.sysdata.xml
    C:\Users\Hp\AppData\Local\Temp\WEREB28.tmp.version.txt
    These are the above notifications which are leading problem to my new laptop....i suddenly get a blue..screen saying dumping physical memory. please help me out.
  2.    25 Aug 2008 #2
    Turnhout, BE
    Vista™ Ultimate x64
    Local Time: 01:11
    belgium european union
    Re: Blue Screen Problem
    Yeah, we need access to those files, not where the files are located.
    And this should be in the General Discussion forum.
    Also tell us what the specifactions are of your laptop.
    What was the thing you last did before the BSODs started to pop up?
blue screen problem
Sir, my laptop shutdown suddenly after if i try to open it then it recovers window vista corrupted files and restarts. this event happened to me...
Crashes and Debugging
blue screen problem
Can someone please tell me what the cause of this blue screen error is? Problem signature: Problem Event Name: BlueScreen OS...
blue screen problem
hello there,im just having a blue screen problem and i cannot log to to my windows,i did already startup repair with my vista installation disk but...
Blue Screen Problem
My pc crashes seemingly at random points in the day, this morning it crashed 3 times and has not since. The info at blue screen is as follows: STOP:...
the problem with ndis.sys Blue Screen of Death problem solved?
there are many ndis.sys Blue Screen of Death postings on the net, but none of them seem to suggest that it is solved. Can it be solved? Or can...
Vista General
blue screen problem
Hi, Having a problem when using the remove hardware safely, this works on everything except the modem,when trying to remove the phone connection I...
Vista hardware & devices
Blue screen problem
playing acouple of games (Americas army and CivilizationIV), after a while my computer crashes with blue screen, saying there is an error w/...
Vista Games
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
