Originally Posted by
fabianloing
Hi everyone,
i am really needing help. I have just bought a new pc, its just about 2 weeks old now....i am running 64bit vista ultimate. The problem is, whenever i click on the power icon ( the little cicle with vertical line on top of it ), my computer would go to "sleep" mode which is fine...but then when i "wake" my pc again, it would probably run for about 10 seconds maximum ( usually 5 seconds or so ), then it would give me blue screen then it would restarts. I would then have to choose if want to load windows normally or safe mode.
I am not tech savvy and i really need help on this one. I really want my new system to be stable for my line of work.
has anyone know the solution to this?
Thank you very much in advance for any help.
Cheers,
Fabian
Self-plagiarism: "Every time the OS crashes it creates a DMP file in the \Windows\minidump directory. That "dump" file is a summary of the software conditions at the time of the crash. Analysis of the dump(s) can frequently help to pinpoint the cause of software-related crashes.
If you copy the latest few DMP files from that folder to a different location, then zip them up and upload the zip file, someone may be able to tell you why the machine is crashing. "
In your case, it's very likely that the crash is caused by a faulty driver which is unable to correctly handle power state transitions.
