Hi, I'm more tech savvy than most, but not a Vista expert. I'm in a state now where I can't get past the blue screen. I've done multiple chkdsks, where it says files are being repaired/deleted, indexes removed, etc., but when I reboot into Vista, things run for a bit, then the blue screen appears. I was able to get into repair mode using F8, and the startup repair says it found and fixed one error (can't remember now what it was), and was able to get into Vista again. I thought I had everything working, but the blue screen again. Now I can't even get to the repair mode. When I boot up, I get an error saying there was a disk read error. The more I try, the worse it seems to get. I've run sfc multiple times, and no errors are found, so that didn't help. I've run memory diagnostices multiple times, and no errors are found. I want to avoid a clean install if possible. How can I get back to repair mode so I can at least run a system restore or partial restore (if that's possible)? I'm at wits end!! Thanks very much.
- eMachines T5234
- AMD Athlon 64 X2 4000+ 2.1GHz, 2x512KB L2 cache
- 1024MB 667MHz DDR2 dual-channel memory (2 × 512MB)
- Realtek High Definition Audio
- NVIDIA GeForce 6150SE nForce 430
- 1024 x 768 x 75 hertz
- WDC WD32 00AAJS-00VWA SCSI Disk Device
- Standard PS/2 Keyboard
- PS/2 Compatible Mouse
- 20M download, 5M upload
- Other Info
- Verizon FIOS
ATAPI DVD A DH16A1P ATA Device
