BSOD Problem Please HELP!
xtoned
Hello, Vista Forums Community.
I have been getting an BSOD error since late May; I re-imaged the computer, but I still get the same problem when I run many processes at a time. The funny thing is that when I take out one of the Ram memory slots, it runs perfectly (when it uses the max 4gb, it crashes).
I have a Toshiba Satellite A305-S6858 with the following:
Intel Core 2 Duo 2GHz Processor
Intel G965 Chipset
Originally 2 banks of PC2-5300 DDR2-667 2GB to form a total of 4GB; which I replaced for 2 banks of PC2-6400 DDR2-800 total of 4GB thinking my problem was within the physical memory.
Attached, my minidump files.
I would appreciate if someone could lead me in the right direction.
Thank you.
  • Minidump_files_zip.zip
    2x Intel(R) Core(TM)2 Duo CPU T5750 @ 2.00GHz
    Intel GM965 Chipset
    DDR2 Kingston PC2/6400 800MHz total of 4GB (2 slots of 2GB ea)
    Mobile Intel(R) 965 Express Chipset
    Generic PnP Monitor Mobile Intel(R) 965 Express Chipset Family
    1280x800 32 bit
    Hitachi HTS543232L9SA00
    Synaptics PS/2 Port TouchPad
    72Mbps
Your Report
Code:
[B]Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64[/B]
[B]Copyright (c) Microsoft Corporation. All rights reserved.[/B]
[B]Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Minidump_files_zip[1].zip\Mini061610-01.dmp][/B]
[B]Mini Kernel Dump File: Only registers and stack trace are available[/B]
[B]Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols[/B]
[B]Executable search path is: [/B]
[B]Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64[/B]
[B]Product: WinNt, suite: TerminalServer SingleUserTS Personal[/B]
[B]Built by: 6001.18000.amd64fre.longhorn_rtm.080118-1840[/B]
[B]Machine Name:[/B]
[B]Kernel base = 0xfffff800`0200c000 PsLoadedModuleList = 0xfffff800`021d1db0[/B]
[B]Debug session time: Wed Jun 16 19:08:04.059 2010 (GMT-4)[/B]
[B]System Uptime: 0 days 0:09:49.842[/B]
[B]Loading Kernel Symbols[/B]
[B]...............................................................[/B]
[B]................................................................[/B]
[B]..................[/B]
[B]Loading User Symbols[/B]
[B]Loading unloaded module list[/B]
[B]..[/B]
[B]*******************************************************************************[/B]
[B]*        *[/B]
[B]*                        Bugcheck Analysis                                    *[/B]
[B]*        *[/B]
[B]Use !analyze -v to get detailed debugging information.[/B]
[B]BugCheck A, {9940000007e, 2, 1, fffff8000206c163}[/B]
[B]Unable to load image \SystemRoot\system32\DRIVERS\NETw4v64.sys, Win32 error 0n2[/B]
[B]*** WARNING: Unable to verify timestamp for NETw4v64.sys[/B]
[B]*** ERROR: Module load completed but symbols could not be loaded for NETw4v64.sys[/B]
[B]Probably caused by : NETw4v64.sys ( NETw4v64+66645 )[/B]
[B]Followup: MachineOwner[/B]
[B]---------[/B]
[B]0: kd> !analyze -v[/B]
[B]*        *[/B]
[B]*        *[/B]
[B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
[B]An attempt was made to access a pageable (or completely invalid) address at an[/B]
[B]interrupt request level (IRQL) that is too high.  This is usually[/B]
[B]caused by drivers using improper addresses.[/B]
[B]If a kernel debugger is available get the stack backtrace.[/B]
[B]Arguments:[/B]
[B]Arg1: 000009940000007e, memory referenced[/B]
[B]Arg2: 0000000000000002, IRQL[/B]
[B]Arg3: 0000000000000001, bitfield :[/B]
[B]bit 0 : value 0 = read operation, 1 = write operation[/B]
[B]bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)[/B]
[B]Arg4: fffff8000206c163, address which referenced memory[/B]
[B]Debugging Details:[/B]
[B]------------------[/B]
[B]WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002235080[/B]
[B]000009940000007e [/B]
[B]CURRENT_IRQL:  2[/B]
[B]FAULTING_IP: [/B]
[B]nt!KeAcquireSpinLockRaiseToDpc+13[/B]
[B]fffff800`0206c163 f0480fba2900    lock bts qword ptr [rcx],0[/B]
[B]CUSTOMER_CRASH_COUNT:  1[/B]
[B]DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT[/B]
[B]BUGCHECK_STR:  0xA[/B]
[B]PROCESS_NAME:  BitComet.exe[/B]
[B]TRAP_FRAME:  fffffa601a7abb10 -- (.trap 0xfffffa601a7abb10)[/B]
[B]NOTE: The trap frame does not contain all registers.[/B]
[B]Some register values may be zeroed or incorrect.[/B]
[B]rax=0000000000000002 rbx=0000000000000000 rcx=000009940000007e[/B]
[B]rdx=fffffa8005cf1340 rsi=0000000000000000 rdi=0000000000000000[/B]
[B]rip=fffff8000206c163 rsp=fffffa601a7abca0 rbp=0000000000000001[/B]
[B]r8=0000000000000000  r9=0000000000000002 r10=713a31793a31b8b2[/B]
[B]r11=fffffa601a7abdb0 r12=0000000000000000 r13=0000000000000000[/B]
[B]r14=0000000000000000 r15=0000000000000000[/B]
[B]iopl=0         nv up ei ng nz na po nc[/B]
[B]nt!KeAcquireSpinLockRaiseToDpc+0x13:[/B]
[B]fffff800`0206c163 f0480fba2900    lock bts qword ptr [rcx],0 ds:00000994`0000007e=????????????????[/B]
[B]Resetting default scope[/B]
[B]LAST_CONTROL_TRANSFER:  from fffff8000206112e to fffff80002061390[/B]
[B]STACK_TEXT:  [/B]
[B]fffffa60`1a7ab9c8 fffff800`0206112e : 00000000`0000000a 00000994`0000007e 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx[/B]
[B]fffffa60`1a7ab9d0 fffff800`0206000b : 00000000`00000001 fffffa60`1a7abb70 fffffa60`1937ba00 00000000`00000000 : nt!KiBugCheckDispatch+0x6e[/B]
[B]fffffa60`1a7abb10 fffff800`0206c163 : 00000000`00000000 fffffa80`05f45990 fffffa80`076d3000 fffffa80`06bd3cc0 : nt!KiPageFault+0x20b[/B]
[B]fffffa60`1a7abca0 fffffa60`02e6e645 : 00000000`00000000 fffff800`020a7c68 00000000`03e46068 00000000`00001000 : nt!KeAcquireSpinLockRaiseToDpc+0x13[/B]
[B]fffffa60`1a7abcd0 00000000`00000000 : fffff800`020a7c68 00000000`03e46068 00000000`00001000 00000000`00000000 : NETw4v64+0x66645[/B]
[B]STACK_COMMAND:  kb[/B]
[B]FOLLOWUP_IP: [/B]
[B]NETw4v64+66645[/B]
[B]fffffa60`02e6e645 ??              ???[/B]
[B]SYMBOL_STACK_INDEX:  4[/B]
[B]SYMBOL_NAME:  NETw4v64+66645[/B]
[B]FOLLOWUP_NAME:  MachineOwner[/B]
[B]MODULE_NAME: NETw4v64[/B]
[B]IMAGE_NAME:  NETw4v64.sys[/B]
[B]DEBUG_FLR_IMAGE_TIMESTAMP:  46fa5c47[/B]
[B]FAILURE_BUCKET_ID:  X64_0xA_NETw4v64+66645[/B]
[B]BUCKET_ID:  X64_0xA_NETw4v64+66645[/B]
[B]---------[/B]
[B]0: kd> lmtsmn[/B]
[B]start             end                 module name[/B]
[B]fffffa60`03131000 fffffa60`03140f00   1394BUS  1394BUS.SYS  Sat Jan 19 01:34:04 2008 (479199DC)[/B]
[B]fffffa60`008ee000 fffffa60`00944000   acpi     acpi.sys     Sat Jan 19 01:02:45 2008 (47919285)[/B]
[B]fffffa60`06971000 fffffa60`0697c000   AegisP   AegisP.sys   Thu Jul 12 15:57:49 2007 (469687BD)[/B]
[B]fffffa60`06608000 fffffa60`06675000   afd      afd.sys      Sat Jan 19 01:38:15 2008 (47919AD7)[/B]
[B]fffffa60`06968000 fffffa60`06971000   aswFsBlk aswFsBlk.SYS Thu May 06 16:33:48 2010 (4BE327AC)[/B]
[B]fffffa60`0694d000 fffffa60`06968000   aswMonFlt aswMonFlt.sys Thu May 06 16:34:13 2010 (4BE327C5)[/B]
[B]fffffa60`06675000 fffffa60`0667f000   aswRdr   aswRdr.SYS   Thu May 06 16:34:28 2010 (4BE327D4)[/B]
[B]fffffa60`06782000 fffffa60`067a5000   aswSP    aswSP.SYS    Thu May 06 16:39:05 2010 (4BE328E9)[/B]
[B]fffffa60`00def000 fffffa60`00dff000   aswTdi   aswTdi.SYS   Thu May 06 16:39:25 2010 (4BE328FD)[/B]
[B]fffffa60`00b07000 fffffa60`00b0f000   atapi    atapi.sys    Sat Jan 19 01:28:49 2008 (479198A1)[/B]
[B]fffffa60`00b0f000 fffffa60`00b33000   ataport  ataport.SYS  Sat Jan 19 01:28:52 2008 (479198A4)[/B]
[B]fffffa60`009a0000 fffffa60`009ac000   BATTC    BATTC.SYS    Sat Jan 19 01:02:38 2008 (4791927E)[/B]
[B]fffffa60`186cc000 fffffa60`186ea000   bowser   bowser.sys   Sat Jan 19 00:54:51 2008 (479190AB)[/B]
[B]fffff960`006b0000 fffff960`006c1000   cdd      cdd.dll      Sat Jan 19 02:54:15 2008 (4791ACA7)[/B]
[B]fffffa60`18965000 fffffa60`18981000   cdfs     cdfs.sys     Sat Jan 19 00:53:45 2008 (47919069)[/B]
[B]fffffa60`00db6000 fffffa60`00dd2000   cdrom    cdrom.sys    Sat Jan 19 01:29:04 2008 (479198B0)[/B]
[B]fffffa60`006b3000 fffffa60`00764000   CI       CI.dll       Sat Jan 19 02:57:59 2008 (4791AD87)[/B]
[B]fffffa60`00fce000 fffffa60`00ffa000   CLASSPNP CLASSPNP.SYS Sat Jan 19 01:28:53 2008 (479198A5)[/B]
[B]fffffa60`00656000 fffffa60`006b3000   CLFS     CLFS.SYS     Sat Jan 19 00:53:58 2008 (47919076)[/B]
[B]fffffa60`02335000 fffffa60`02339580   CmBatt   CmBatt.sys   Sat Jan 19 01:02:42 2008 (47919282)[/B]
[B]fffffa60`0099c000 fffffa60`0099f400   compbatt compbatt.sys Sat Jan 19 01:02:42 2008 (47919282)[/B]
[B]fffffa60`02200000 fffffa60`0220e000   crashdmp crashdmp.sys Sat Jan 19 01:28:59 2008 (479198AB)[/B]
[B]fffffa60`013f5000 fffffa60`013ff000   crcdisk  crcdisk.sys  Sat Jan 19 01:30:12 2008 (479198F4)[/B]
[B]fffffa60`06765000 fffffa60`06782000   dfsc     dfsc.sys     Sat Jan 19 00:54:16 2008 (47919088)[/B]
[B]fffffa60`011d9000 fffffa60`011ed000   disk     disk.sys     Sat Jan 19 01:29:02 2008 (479198AE)[/B]
[B]fffffa60`0658e000 fffffa60`065b1000   drmk     drmk.sys     Sat Jan 19 02:20:04 2008 (4791A4A4)[/B]
[B]fffffa60`06808000 fffffa60`0690c000   dump_iaStor dump_iaStor.sys Sun Sep 30 01:36:30 2007 (46FF35DE)[/B]
[B]fffffa60`0690c000 fffffa60`06918000   Dxapi    Dxapi.sys    Sat Jan 19 01:08:00 2008 (479193C0)[/B]
[B]fffffa60`02ac6000 fffffa60`02ba5000   dxgkrnl  dxgkrnl.sys  Sat Jan 19 01:08:38 2008 (479193E6)[/B]
[B]fffffa60`011ad000 fffffa60`011d9000   ecache   ecache.sys   Sat Jan 19 01:30:39 2008 (4791990F)[/B]
[B]fffffa60`00b83000 fffffa60`00b97000   fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)[/B]
[B]fffffa60`00b3d000 fffffa60`00b83000   fltmgr   fltmgr.sys   Sat Jan 19 00:54:10 2008 (47919082)[/B]
[B]fffffa60`065b7000 fffffa60`065c1000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:53:41 2008 (47919065)[/B]
[B]fffffa60`0231a000 fffffa60`02322000   FwLnk    FwLnk.sys    Sun Nov 19 09:11:04 2006 (456065F8)[/B]
[B]fffffa60`01181000 fffffa60`011ad000   fwpkclnt fwpkclnt.sys Sat Jan 19 01:36:43 2008 (47919A7B)[/B]
[B]fffffa60`011ed000 fffffa60`011fa000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)[/B]
[B]fffff800`02524000 fffff800`0256a000   hal      hal.dll      Sat Jan 19 02:55:25 2008 (4791ACED)[/B]
[B]fffffa60`02bd1000 fffffa60`02be4000   HDAudBus HDAudBus.sys Tue Nov 27 18:24:06 2007 (474CA716)[/B]
[B]fffffa60`18609000 fffffa60`186a4000   HTTP     HTTP.sys     Sat Jan 19 01:36:22 2008 (47919A66)[/B]
[B]fffffa60`031e4000 fffffa60`031fa000   i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)[/B]
[B]fffffa60`00a03000 fffffa60`00b07000   iaStor   iaStor.sys   Sun Sep 30 01:36:30 2007 (46FF35DE)[/B]
[B]fffffa60`0240e000 fffffa60`02ac5120   igdkmd64 igdkmd64.sys Thu Sep 13 18:27:07 2007 (46E9B93B)[/B]
[B]fffffa60`009c0000 fffffa60`009c8000   intelide intelide.sys Sat Jan 19 01:28:56 2008 (479198A8)[/B]
[B]fffffa60`02322000 fffffa60`02335000   intelppm intelppm.sys Sat Jan 19 00:52:45 2008 (4791902D)[/B]
[B]fffffa60`02be4000 fffffa60`02bf2000   kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)[/B]
[B]fffffa60`0060b000 fffffa60`00615000   kdcom    kdcom.dll    Sat Jan 19 02:58:25 2008 (4791ADA1)[/B]
[B]fffffa60`0332e000 fffffa60`03362000   ks       ks.sys       Sat Jan 19 01:28:24 2008 (47919888)[/B]
[B]fffffa60`00c02000 fffffa60`00c87000   ksecdd   ksecdd.sys   Sat Jan 19 01:16:38 2008 (479195C6)[/B]
[B]fffffa60`065b1000 fffffa60`065b6180   ksthunk  ksthunk.sys  Sat Jan 19 01:28:14 2008 (4791987E)[/B]
[B]fffffa60`0697c000 fffffa60`06990000   lltdio   lltdio.sys   Sat Jan 19 01:35:48 2008 (47919A44)[/B]
[B]fffffa60`0692b000 fffffa60`0694d000   luafv    luafv.sys    Sat Jan 19 00:59:06 2008 (479191AA)[/B]
[B]fffffa60`00615000 fffffa60`00642000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Jan 19 02:56:17 2008 (4791AD21)[/B]
[B]fffffa60`06918000 fffffa60`0692b000   monitor  monitor.sys  Sat Jan 19 01:32:34 2008 (47919982)[/B]
[B]fffffa60`02bf2000 fffffa60`02bfe000   mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)[/B]
[B]fffffa60`009d8000 fffffa60`009eb000   mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)[/B]
[B]fffffa60`186ea000 fffffa60`18704000   mpsdrv   mpsdrv.sys   Sat Jan 19 01:35:28 2008 (47919A30)[/B]
[B]fffffa60`18704000 fffffa60`1872b000   mrxdav   mrxdav.sys   Sat Jan 19 00:55:28 2008 (479190D0)[/B]
[B]fffffa60`1872b000 fffffa60`18753000   mrxsmb   mrxsmb.sys   Sat Jan 19 00:55:21 2008 (479190C9)[/B]
[B]fffffa60`18753000 fffffa60`1879c000   mrxsmb10 mrxsmb10.sys Sat Jan 19 00:55:07 2008 (479190BB)[/B]
[B]fffffa60`1879c000 fffffa60`187bb000   mrxsmb20 mrxsmb20.sys Sat Jan 19 00:55:19 2008 (479190C7)[/B]
[B]fffffa60`00b33000 fffffa60`00b3d000   msahci   msahci.sys   Sat Jan 19 01:28:58 2008 (479198AA)[/B]
[B]fffffa60`033e1000 fffffa60`033ec000   Msfs     Msfs.SYS     Sat Jan 19 00:53:55 2008 (47919073)[/B]
[B]fffffa60`0094d000 fffffa60`00957000   msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)[/B]
[B]fffffa60`00b97000 fffffa60`00bcf000   msiscsi  msiscsi.sys  Sat Jan 19 01:30:31 2008 (47919907)[/B]
[B]fffffa60`00c87000 fffffa60`00cd7000   msrpc    msrpc.sys    Sat Jan 19 01:27:01 2008 (47919835)[/B]
[B]fffffa60`03362000 fffffa60`0336d000   mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)[/B]
[B]fffffa60`013e3000 fffffa60`013f5000   mup      mup.sys      Sat Jan 19 00:54:18 2008 (4791908A)[/B]
[B]fffffa60`00e0b000 fffffa60`00fce000   ndis     ndis.sys     Sat Jan 19 01:37:13 2008 (47919A99)[/B]
[B]fffffa60`03297000 fffffa60`032a3000   ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)[/B]
[B]fffffa60`069c4000 fffffa60`069cf000   ndisuio  ndisuio.sys  Sat Jan 19 01:36:29 2008 (47919A6D)[/B]
[B]fffffa60`032a3000 fffffa60`032d4000   ndiswan  ndiswan.sys  Sat Jan 19 01:37:33 2008 (47919AAD)[/B]
[B]fffffa60`033c4000 fffffa60`033d8000   NDProxy  NDProxy.SYS  Sat Jan 19 01:37:26 2008 (47919AA6)[/B]
[B]fffffa60`066e1000 fffffa60`066f0000   netbios  netbios.sys  Sat Jan 19 01:36:35 2008 (47919A73)[/B]
[B]fffffa60`0667f000 fffffa60`066c3000   netbt    netbt.sys    Sat Jan 19 01:36:24 2008 (47919A68)[/B]
[B]fffffa60`00cd7000 fffffa60`00d2f000   NETIO    NETIO.SYS    Sat Jan 19 01:37:27 2008 (47919AA7)[/B]
[B]fffffa60`02e08000 fffffa60`0311f000   NETw4v64 NETw4v64.sys Wed Sep 26 09:19:03 2007 (46FA5C47)[/B]
[B]fffffa60`033ec000 fffffa60`033fd000   Npfs     Npfs.SYS     Sat Jan 19 00:53:57 2008 (47919075)[/B]
[B]fffffa60`06759000 fffffa60`06765000   nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)[/B]
[B]fffff800`0200c000 fffff800`02524000   nt       ntkrnlmp.exe Sat Jan 19 01:03:35 2008 (479192B7)[/B]
[B]fffffa60`0120e000 fffffa60`01392000   Ntfs     Ntfs.sys     Sat Jan 19 00:55:29 2008 (479190D1)[/B]
[B]fffffa60`065c1000 fffffa60`065ca000   Null     Null.SYS     Thu Nov 02 05:37:15 2006 (4549BC4B)[/B]
[B]fffffa60`06990000 fffffa60`069c4000   nwifi    nwifi.sys    Sat Jan 19 01:34:38 2008 (479199FE)[/B]
[B]fffffa60`0311f000 fffffa60`03130a00   ohci1394 ohci1394.sys Sat Jan 19 01:34:08 2008 (479199E0)[/B]
[B]fffffa60`066c3000 fffffa60`066e1000   pacer    pacer.sys    Sat Jan 19 01:36:51 2008 (47919A83)[/B]
[B]fffffa60`00987000 fffffa60`0099c000   partmgr  partmgr.sys  Sat Jan 19 01:29:14 2008 (479198BA)[/B]
[B]fffffa60`00957000 fffffa60`00987000   pci      pci.sys      Sat Jan 19 01:02:57 2008 (47919291)[/B]
[B]fffffa60`009c8000 fffffa60`009d8000   PCIIDEX  PCIIDEX.SYS  Sat Jan 19 01:28:53 2008 (479198A5)[/B]
[B]fffffa60`18895000 fffffa60`1894b000   peauth   peauth.sys   Mon Oct 23 07:57:00 2006 (453CAE0C)[/B]
[B]fffffa60`06553000 fffffa60`0658e000   portcls  portcls.sys  Sat Jan 19 01:33:58 2008 (479199D6)[/B]
[B]fffffa60`00642000 fffffa60`00656000   PSHED    PSHED.dll    Sat Jan 19 02:58:13 2008 (4791AD95)[/B]
[B]fffffa60`03200000 fffffa60`03209000   rasacd   rasacd.sys   Sat Jan 19 01:37:30 2008 (47919AAA)[/B]
[B]fffffa60`03274000 fffffa60`03297000   rasl2tp  rasl2tp.sys  Sat Jan 19 01:37:33 2008 (47919AAD)[/B]
[B]fffffa60`032d4000 fffffa60`032e4000   raspppoe raspppoe.sys Sat Jan 19 01:37:30 2008 (47919AAA)[/B]
[B]fffffa60`032e4000 fffffa60`03302000   raspptp  raspptp.sys  Sat Jan 19 01:37:34 2008 (47919AAE)[/B]
[B]fffffa60`03302000 fffffa60`0331a000   rassstp  rassstp.sys  Sat Jan 19 01:37:42 2008 (47919AB6)[/B]
[B]fffffa60`0670b000 fffffa60`06759000   rdbss    rdbss.sys    Sat Jan 19 00:55:09 2008 (479190BD)[/B]
[B]fffffa60`06400000 fffffa60`06409000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:42:04 2008 (47919BBC)[/B]
[B]fffffa60`033d8000 fffffa60`033e1000   rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)[/B]
[B]fffffa60`03161000 fffffa60`03176000   rimmpx64 rimmpx64.sys Wed Feb 20 20:24:19 2008 (47BCD2C3)[/B]
[B]fffffa60`03176000 fffffa60`0318d000   rimspx64 rimspx64.sys Thu Jul 26 07:33:52 2007 (46A886A0)[/B]
[B]fffffa60`0318d000 fffffa60`031e4000   rixdpx64 rixdpx64.sys Fri Jul 27 06:45:50 2007 (46A9CCDE)[/B]
[B]fffffa60`069cf000 fffffa60`069e7000   rspndr   rspndr.sys   Sat Jan 19 01:35:48 2008 (47919A44)[/B]
[B]fffffa60`06409000 fffffa60`06552200   RTKVHD64 RTKVHD64.sys Tue Jan 29 22:37:09 2008 (479FF0E5)[/B]
[B]fffffa60`02380000 fffffa60`023ab000   Rtlh64   Rtlh64.sys   Thu Feb 14 01:56:12 2008 (47B3E60C)[/B]
[B]fffffa60`03141000 fffffa60`03161000   sdbus    sdbus.sys    Sat Jan 19 01:02:55 2008 (4791928F)[/B]
[B]fffffa60`1894b000 fffffa60`18956000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)[/B]
[B]fffffa60`00bcf000 fffffa60`00bea000   smb      smb.sys      Sat Jan 19 01:36:17 2008 (47919A61)[/B]
[B]fffffa60`013db000 fffffa60`013e3000   spldr    spldr.sys    Thu Jun 21 20:57:56 2007 (467B1E94)[/B]
[B]fffffa60`0220e000 fffffa60`022a8000   spsys    spsys.sys    Thu Jun 21 21:02:05 2007 (467B1F8D)[/B]
[B]fffffa60`18801000 fffffa60`18895000   srv      srv.sys      Sat Jan 19 00:57:09 2008 (47919135)[/B]
[B]fffffa60`187bb000 fffffa60`187ec000   srv2     srv2.sys     Sat Jan 19 00:56:40 2008 (47919118)[/B]
[B]fffffa60`186a4000 fffffa60`186cc000   srvnet   srvnet.sys   Sat Jan 19 00:56:38 2008 (47919116)[/B]
[B]fffffa60`0320a000 fffffa60`03267000   storport storport.sys Sat Jan 19 01:29:09 2008 (479198B5)[/B]
[B]fffffa60`0332c000 fffffa60`0332d480   swenum   swenum.sys   Thu Nov 02 05:37:33 2006 (4549BC5D)[/B]
[B]fffffa60`023ab000 fffffa60`02400000   SynTP    SynTP.sys    Thu Dec 06 20:42:03 2007 (4758A4EB)[/B]
[B]fffffa60`0100d000 fffffa60`01181000   tcpip    tcpip.sys    Sat Jan 19 01:38:58 2008 (47919B02)[/B]
[B]fffffa60`18956000 fffffa60`18965000   tcpipreg tcpipreg.sys Sat Jan 19 01:37:01 2008 (47919A8D)[/B]
[B]fffffa60`02400000 fffffa60`0240a000   tdcmdpst tdcmdpst.sys Wed Oct 18 03:08:01 2006 (4535D2D1)[/B]
[B]fffffa60`03267000 fffffa60`03274000   TDI      TDI.SYS      Sat Jan 19 01:38:11 2008 (47919AD3)[/B]
[B]fffffa60`00dd2000 fffffa60`00def000   tdx      tdx.sys      Sat Jan 19 01:36:53 2008 (47919A85)[/B]
[B]fffffa60`0331a000 fffffa60`0332c000   termdd   termdd.sys   Sat Jan 19 01:42:03 2008 (47919BBB)[/B]
[B]fffffa60`00d2f000 fffffa60`00db6000   tos_sps64 tos_sps64.sys Wed Dec 20 00:36:20 2006 (4588CBD4)[/B]
[B]fffff960`00490000 fffff960`0049a000   TSDDD    TSDDD.dll    unavailable (00000000)[/B]
[B]fffffa60`02311000 fffffa60`0231a000   tunmp    tunmp.sys    Sat Jan 19 01:36:30 2008 (47919A6E)[/B]
[B]fffffa60`02305000 fffffa60`02311000   tunnel   tunnel.sys   Sat Jan 19 01:36:44 2008 (47919A7C)[/B]
[B]fffffa60`013d6000 fffffa60`013dae80   TVALZ_O  TVALZ_O.SYS  Thu Nov 08 22:08:41 2007 (4733CF39)[/B]
[B]fffffa60`0336d000 fffffa60`0337d000   umbus    umbus.sys    Sat Jan 19 01:34:16 2008 (479199E8)[/B]
[B]fffffa60`067a5000 fffffa60`067c1000   usbccgp  usbccgp.sys  Sat Jan 19 01:34:04 2008 (479199DC)[/B]
[B]fffffa60`031fa000 fffffa60`031fbe00   USBD     USBD.SYS     Sat Jan 19 01:33:53 2008 (479199D1)[/B]
[B]fffffa60`02bc0000 fffffa60`02bd1000   usbehci  usbehci.sys  Sat Jan 19 01:33:57 2008 (479199D5)[/B]
[B]fffffa60`0337d000 fffffa60`033c4000   usbhub   usbhub.sys   Sat Jan 19 01:34:13 2008 (479199E5)[/B]
[B]fffffa60`0233a000 fffffa60`02380000   USBPORT  USBPORT.SYS  Sat Jan 19 01:34:00 2008 (479199D8)[/B]
[B]fffffa60`02bb4000 fffffa60`02bc0000   usbuhci  usbuhci.sys  Sat Jan 19 01:33:56 2008 (479199D4)[/B]
[B]fffffa60`067cc000 fffffa60`067f5300   usbvideo usbvideo.sys Sat Jan 19 01:34:14 2008 (479199E6)[/B]
[B]fffffa60`067c1000 fffffa60`067cc000   UVCFTR_S UVCFTR_S.SYS Tue Nov 27 05:38:38 2007 (474BF3AE)[/B]
[B]fffffa60`065ca000 fffffa60`065d8000   vga      vga.sys      Sat Jan 19 01:32:21 2008 (47919975)[/B]
[B]fffffa60`065d8000 fffffa60`065fd000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)[/B]
[B]fffffa60`009ac000 fffffa60`009c0000   volmgr   volmgr.sys   Sat Jan 19 01:29:12 2008 (479198B8)[/B]
[B]fffffa60`00764000 fffffa60`007ca000   volmgrx  volmgrx.sys  Sat Jan 19 01:29:45 2008 (479198D9)[/B]
[B]fffffa60`01392000 fffffa60`013d6000   volsnap  volsnap.sys  Sat Jan 19 01:29:47 2008 (479198DB)[/B]
[B]fffffa60`066f0000 fffffa60`0670b000   wanarp   wanarp.sys   Sat Jan 19 01:37:35 2008 (47919AAF)[/B]
[B]fffffa60`02ba5000 fffffa60`02bb4000   watchdog watchdog.sys Sat Jan 19 01:07:23 2008 (4791939B)[/B]
[B]fffffa60`00806000 fffffa60`008e0000   Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)[/B]
[B]fffffa60`008e0000 fffffa60`008ee000   WDFLDR   WDFLDR.SYS   Sat Jan 19 01:32:33 2008 (47919981)[/B]
[B]fffff960`000e0000 fffff960`00390000   win32k   win32k.sys   Sat Jan 19 01:10:09 2008 (47919441)[/B]
[B]fffffa60`00944000 fffffa60`0094d000   WMILIB   WMILIB.SYS   Sat Jan 19 01:33:45 2008 (479199C9)[/B]
[B]Unloaded modules:[/B]
[B]fffffa60`01200000 fffffa60`0120e000   crashdmp.sys[/B]
[B]Timestamp: unavailable (00000000)[/B]
[B]Checksum:  00000000[/B]
[B]fffffa60`02201000 fffffa60`02305000   dump_iaStor.[/B]
Usual Causes
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility
Your probable cause:
NETw4v64.sys
Solution
Based upon your Dump report I must make the following suggestions:
Go to Intel site and update the above driver (I think it is Intel)
Virus Scan
SFC /scannow
If the problem is not solved by updating the driver and following my other suggestions: uninstall your anti virus and install Microsoft Security Essentials.
If the BSOD continue after that, post the new report. If I am able I will help, or if not hopefully other members will stop by.
SFC /SCANNOW Command - System File Checker - Windows 7 Forums Update Drivers
I was not going to post, since I am really pressed for time and will be on a travel status soon. If this does not solve the problem any other member should feel free to offer help.
If no other help is offered, post the new BSOD after following all my instructions and I will post as soon as possible.
Thank you very much!
I updated the NETw4v64.sys file from INTEL, and the system has been ongoing for a whole hour without crashing. Normally it would soon crash after I started downloading heavy files and opened another process.
Again, thank you very much.
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
Glad to help. Your problem looked like it was easy to fix, but I almost did not answer; since I would not be around, while on trave staus, if it did not work.
In any event, good luck and enjoy.
I would, appreciate it if you report back after about a week or so to indicate the status of your computer. An hour's use really does not tell much, but I think that it is repaired.
I will get back to y'all about the BSOD. So far it's working great. Again, thank you so much on that. However, now I am having trouble with the following:
WindowsUpdate_8024402F
I have re-imaged my computer, and ever since, the windows update agent has not worked properly. I have not been able to update my OS in some time now. I have tried disabling antivirus, firewall, 3rd party security appz, etc.
My OS is Windows Vista Home Premium 64 bit, service pack 2 (I actually had to download it manually and install it).
So far, nothing seems to work. Do you have any idea on this?
Thank you and have a safe trip.
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
Your Report
Code:
[B]..[/B]
[B]*        *[/B]
[B]*        *[/B]
[B]---------[/B]
[B]*        *[/B]
[B]*        *[/B]
[B]Arguments:[/B]
[B]STACK_TEXT:  [/B]
[B]---------[/B]
Usual Causes
NETw4v64.sys
Solution
Virus Scan
SFC /scannow
Try the SFC command, given here.
Hello, richc46.
I performed the SFC scan. This is what I came up with:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>SFC /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some of th
em.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
C:\Windows\Logs\CBS\CBS.log
I am attaching the CBS log zipped. Pls check it when you have the time, and let me know. Thanks for your assistance. This windows update thing is annoying.
Rgds,
xtoned.
  • CBS.zip
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
. The procedure is to run sfc several times if errors are found. It it is still not repaired a repair install is suggested.
The only errors that I found were the side bar and that refers to gadgets.
Ok. Will perform SFC various times.
What do you exactly mean by a repair install?
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
The thing is, richc46, that I just perfomed a complete re-image of the computer last night. I erased the whole hard drive and installed windows vista home premium 64 bit out of the factory cd that came with the computer.
The windows update problem I had before I did the re-image, and I still do.
Wouldnt the re-image be considered somewhat of a repair install in that case?
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
Hello, richc46.
Thank you for that amazing link; really handy.
I really do not know what exactly helped the most, if the SFC scan, or the Windows Live OneCare scan. The thing is, after I restarted the computer, it went to download the win update files by itself. After downloading, it went to normal installation.
I really do want to thank you for your time and assistance. The computer seems to be working in prime condition.
Again, thanks.
Respectfully,
xtoned.
    Intel GM965 Chipset
    1280x800 32 bit
    72Mbps
You are most welcome. Come back often and bring your friends. .
