[B]Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64[/B]
[B]Copyright (c) Microsoft Corporation. All rights reserved.[/B]
[B]Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Minidump_files_zip[1].zip\Mini061610-01.dmp][/B]
[B]Mini Kernel Dump File: Only registers and stack trace are available[/B]
[B]Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols[/B]
[B]Executable search path is: [/B]
[B]Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64[/B]
[B]Product: WinNt, suite: TerminalServer SingleUserTS Personal[/B]
[B]Built by: 6001.18000.amd64fre.longhorn_rtm.080118-1840[/B]
[B]Machine Name:[/B]
[B]Kernel base = 0xfffff800`0200c000 PsLoadedModuleList = 0xfffff800`021d1db0[/B]
[B]Debug session time: Wed Jun 16 19:08:04.059 2010 (GMT-4)[/B]
[B]System Uptime: 0 days 0:09:49.842[/B]
[B]Loading Kernel Symbols[/B]
[B]...............................................................[/B]
[B]................................................................[/B]
[B]..................[/B]
[B]Loading User Symbols[/B]
[B]Loading unloaded module list[/B]
[B]..[/B]
[B]*******************************************************************************[/B]
[B]* *[/B]
[B]* Bugcheck Analysis *[/B]
[B]* *[/B]
[B]Use !analyze -v to get detailed debugging information.[/B]
[B]BugCheck A, {9940000007e, 2, 1, fffff8000206c163}[/B]
[B]Unable to load image \SystemRoot\system32\DRIVERS\NETw4v64.sys, Win32 error 0n2[/B]
[B]*** WARNING: Unable to verify timestamp for NETw4v64.sys[/B]
[B]*** ERROR: Module load completed but symbols could not be loaded for NETw4v64.sys[/B]
[B]Probably caused by : NETw4v64.sys ( NETw4v64+66645 )[/B]
[B]Followup: MachineOwner[/B]
[B]---------[/B]
[B]0: kd> !analyze -v[/B]
[B]* *[/B]
[B]* *[/B]
[B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
[B]An attempt was made to access a pageable (or completely invalid) address at an[/B]
[B]interrupt request level (IRQL) that is too high. This is usually[/B]
[B]caused by drivers using improper addresses.[/B]
[B]If a kernel debugger is available get the stack backtrace.[/B]
[B]Arguments:[/B]
[B]Arg1: 000009940000007e, memory referenced[/B]
[B]Arg2: 0000000000000002, IRQL[/B]
[B]Arg3: 0000000000000001, bitfield :[/B]
[B]bit 0 : value 0 = read operation, 1 = write operation[/B]
[B]bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)[/B]
[B]Arg4: fffff8000206c163, address which referenced memory[/B]
[B]Debugging Details:[/B]
[B]------------------[/B]
[B]WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002235080[/B]
[B]000009940000007e [/B]
[B]CURRENT_IRQL: 2[/B]
[B]FAULTING_IP: [/B]
[B]nt!KeAcquireSpinLockRaiseToDpc+13[/B]
[B]fffff800`0206c163 f0480fba2900 lock bts qword ptr [rcx],0[/B]
[B]CUSTOMER_CRASH_COUNT: 1[/B]
[B]DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT[/B]
[B]BUGCHECK_STR: 0xA[/B]
[B]PROCESS_NAME: BitComet.exe[/B]
[B]TRAP_FRAME: fffffa601a7abb10 -- (.trap 0xfffffa601a7abb10)[/B]
[B]NOTE: The trap frame does not contain all registers.[/B]
[B]Some register values may be zeroed or incorrect.[/B]
[B]rax=0000000000000002 rbx=0000000000000000 rcx=000009940000007e[/B]
[B]rdx=fffffa8005cf1340 rsi=0000000000000000 rdi=0000000000000000[/B]
[B]rip=fffff8000206c163 rsp=fffffa601a7abca0 rbp=0000000000000001[/B]
[B]r8=0000000000000000 r9=0000000000000002 r10=713a31793a31b8b2[/B]
[B]r11=fffffa601a7abdb0 r12=0000000000000000 r13=0000000000000000[/B]
[B]r14=0000000000000000 r15=0000000000000000[/B]
[B]iopl=0 nv up ei ng nz na po nc[/B]
[B]nt!KeAcquireSpinLockRaiseToDpc+0x13:[/B]
[B]fffff800`0206c163 f0480fba2900 lock bts qword ptr [rcx],0 ds:00000994`0000007e=????????????????[/B]
[B]Resetting default scope[/B]
[B]LAST_CONTROL_TRANSFER: from fffff8000206112e to fffff80002061390[/B]
[B]STACK_TEXT: [/B]
[B]fffffa60`1a7ab9c8 fffff800`0206112e : 00000000`0000000a 00000994`0000007e 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx[/B]
[B]fffffa60`1a7ab9d0 fffff800`0206000b : 00000000`00000001 fffffa60`1a7abb70 fffffa60`1937ba00 00000000`00000000 : nt!KiBugCheckDispatch+0x6e[/B]
[B]fffffa60`1a7abb10 fffff800`0206c163 : 00000000`00000000 fffffa80`05f45990 fffffa80`076d3000 fffffa80`06bd3cc0 : nt!KiPageFault+0x20b[/B]
[B]fffffa60`1a7abca0 fffffa60`02e6e645 : 00000000`00000000 fffff800`020a7c68 00000000`03e46068 00000000`00001000 : nt!KeAcquireSpinLockRaiseToDpc+0x13[/B]
[B]fffffa60`1a7abcd0 00000000`00000000 : fffff800`020a7c68 00000000`03e46068 00000000`00001000 00000000`00000000 : NETw4v64+0x66645[/B]
[B]STACK_COMMAND: kb[/B]
[B]FOLLOWUP_IP: [/B]
[B]NETw4v64+66645[/B]
[B]fffffa60`02e6e645 ?? ???[/B]
[B]SYMBOL_STACK_INDEX: 4[/B]
[B]SYMBOL_NAME: NETw4v64+66645[/B]
[B]FOLLOWUP_NAME: MachineOwner[/B]
[B]MODULE_NAME: NETw4v64[/B]
[B]IMAGE_NAME: NETw4v64.sys[/B]
[B]DEBUG_FLR_IMAGE_TIMESTAMP: 46fa5c47[/B]
[B]FAILURE_BUCKET_ID: X64_0xA_NETw4v64+66645[/B]
[B]BUCKET_ID: X64_0xA_NETw4v64+66645[/B]
[B]---------[/B]
[B]0: kd> lmtsmn[/B]
[B]start end module name[/B]
[B]fffffa60`03131000 fffffa60`03140f00 1394BUS 1394BUS.SYS Sat Jan 19 01:34:04 2008 (479199DC)[/B]
[B]fffffa60`008ee000 fffffa60`00944000 acpi acpi.sys Sat Jan 19 01:02:45 2008 (47919285)[/B]
[B]fffffa60`06971000 fffffa60`0697c000 AegisP AegisP.sys Thu Jul 12 15:57:49 2007 (469687BD)[/B]
[B]fffffa60`06608000 fffffa60`06675000 afd afd.sys Sat Jan 19 01:38:15 2008 (47919AD7)[/B]
[B]fffffa60`06968000 fffffa60`06971000 aswFsBlk aswFsBlk.SYS Thu May 06 16:33:48 2010 (4BE327AC)[/B]
[B]fffffa60`0694d000 fffffa60`06968000 aswMonFlt aswMonFlt.sys Thu May 06 16:34:13 2010 (4BE327C5)[/B]
[B]fffffa60`06675000 fffffa60`0667f000 aswRdr aswRdr.SYS Thu May 06 16:34:28 2010 (4BE327D4)[/B]
[B]fffffa60`06782000 fffffa60`067a5000 aswSP aswSP.SYS Thu May 06 16:39:05 2010 (4BE328E9)[/B]
[B]fffffa60`00def000 fffffa60`00dff000 aswTdi aswTdi.SYS Thu May 06 16:39:25 2010 (4BE328FD)[/B]
[B]fffffa60`00b07000 fffffa60`00b0f000 atapi atapi.sys Sat Jan 19 01:28:49 2008 (479198A1)[/B]
[B]fffffa60`00b0f000 fffffa60`00b33000 ataport ataport.SYS Sat Jan 19 01:28:52 2008 (479198A4)[/B]
[B]fffffa60`009a0000 fffffa60`009ac000 BATTC BATTC.SYS Sat Jan 19 01:02:38 2008 (4791927E)[/B]
[B]fffffa60`186cc000 fffffa60`186ea000 bowser bowser.sys Sat Jan 19 00:54:51 2008 (479190AB)[/B]
[B]fffff960`006b0000 fffff960`006c1000 cdd cdd.dll Sat Jan 19 02:54:15 2008 (4791ACA7)[/B]
[B]fffffa60`18965000 fffffa60`18981000 cdfs cdfs.sys Sat Jan 19 00:53:45 2008 (47919069)[/B]
[B]fffffa60`00db6000 fffffa60`00dd2000 cdrom cdrom.sys Sat Jan 19 01:29:04 2008 (479198B0)[/B]
[B]fffffa60`006b3000 fffffa60`00764000 CI CI.dll Sat Jan 19 02:57:59 2008 (4791AD87)[/B]
[B]fffffa60`00fce000 fffffa60`00ffa000 CLASSPNP CLASSPNP.SYS Sat Jan 19 01:28:53 2008 (479198A5)[/B]
[B]fffffa60`00656000 fffffa60`006b3000 CLFS CLFS.SYS Sat Jan 19 00:53:58 2008 (47919076)[/B]
[B]fffffa60`02335000 fffffa60`02339580 CmBatt CmBatt.sys Sat Jan 19 01:02:42 2008 (47919282)[/B]
[B]fffffa60`0099c000 fffffa60`0099f400 compbatt compbatt.sys Sat Jan 19 01:02:42 2008 (47919282)[/B]
[B]fffffa60`02200000 fffffa60`0220e000 crashdmp crashdmp.sys Sat Jan 19 01:28:59 2008 (479198AB)[/B]
[B]fffffa60`013f5000 fffffa60`013ff000 crcdisk crcdisk.sys Sat Jan 19 01:30:12 2008 (479198F4)[/B]
[B]fffffa60`06765000 fffffa60`06782000 dfsc dfsc.sys Sat Jan 19 00:54:16 2008 (47919088)[/B]
[B]fffffa60`011d9000 fffffa60`011ed000 disk disk.sys Sat Jan 19 01:29:02 2008 (479198AE)[/B]
[B]fffffa60`0658e000 fffffa60`065b1000 drmk drmk.sys Sat Jan 19 02:20:04 2008 (4791A4A4)[/B]
[B]fffffa60`06808000 fffffa60`0690c000 dump_iaStor dump_iaStor.sys Sun Sep 30 01:36:30 2007 (46FF35DE)[/B]
[B]fffffa60`0690c000 fffffa60`06918000 Dxapi Dxapi.sys Sat Jan 19 01:08:00 2008 (479193C0)[/B]
[B]fffffa60`02ac6000 fffffa60`02ba5000 dxgkrnl dxgkrnl.sys Sat Jan 19 01:08:38 2008 (479193E6)[/B]
[B]fffffa60`011ad000 fffffa60`011d9000 ecache ecache.sys Sat Jan 19 01:30:39 2008 (4791990F)[/B]
[B]fffffa60`00b83000 fffffa60`00b97000 fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)[/B]
[B]fffffa60`00b3d000 fffffa60`00b83000 fltmgr fltmgr.sys Sat Jan 19 00:54:10 2008 (47919082)[/B]
[B]fffffa60`065b7000 fffffa60`065c1000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:53:41 2008 (47919065)[/B]
[B]fffffa60`0231a000 fffffa60`02322000 FwLnk FwLnk.sys Sun Nov 19 09:11:04 2006 (456065F8)[/B]
[B]fffffa60`01181000 fffffa60`011ad000 fwpkclnt fwpkclnt.sys Sat Jan 19 01:36:43 2008 (47919A7B)[/B]
[B]fffffa60`011ed000 fffffa60`011fa000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)[/B]
[B]fffff800`02524000 fffff800`0256a000 hal hal.dll Sat Jan 19 02:55:25 2008 (4791ACED)[/B]
[B]fffffa60`02bd1000 fffffa60`02be4000 HDAudBus HDAudBus.sys Tue Nov 27 18:24:06 2007 (474CA716)[/B]
[B]fffffa60`18609000 fffffa60`186a4000 HTTP HTTP.sys Sat Jan 19 01:36:22 2008 (47919A66)[/B]
[B]fffffa60`031e4000 fffffa60`031fa000 i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)[/B]
[B]fffffa60`00a03000 fffffa60`00b07000 iaStor iaStor.sys Sun Sep 30 01:36:30 2007 (46FF35DE)[/B]
[B]fffffa60`0240e000 fffffa60`02ac5120 igdkmd64 igdkmd64.sys Thu Sep 13 18:27:07 2007 (46E9B93B)[/B]
[B]fffffa60`009c0000 fffffa60`009c8000 intelide intelide.sys Sat Jan 19 01:28:56 2008 (479198A8)[/B]
[B]fffffa60`02322000 fffffa60`02335000 intelppm intelppm.sys Sat Jan 19 00:52:45 2008 (4791902D)[/B]
[B]fffffa60`02be4000 fffffa60`02bf2000 kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)[/B]
[B]fffffa60`0060b000 fffffa60`00615000 kdcom kdcom.dll Sat Jan 19 02:58:25 2008 (4791ADA1)[/B]
[B]fffffa60`0332e000 fffffa60`03362000 ks ks.sys Sat Jan 19 01:28:24 2008 (47919888)[/B]
[B]fffffa60`00c02000 fffffa60`00c87000 ksecdd ksecdd.sys Sat Jan 19 01:16:38 2008 (479195C6)[/B]
[B]fffffa60`065b1000 fffffa60`065b6180 ksthunk ksthunk.sys Sat Jan 19 01:28:14 2008 (4791987E)[/B]
[B]fffffa60`0697c000 fffffa60`06990000 lltdio lltdio.sys Sat Jan 19 01:35:48 2008 (47919A44)[/B]
[B]fffffa60`0692b000 fffffa60`0694d000 luafv luafv.sys Sat Jan 19 00:59:06 2008 (479191AA)[/B]
[B]fffffa60`00615000 fffffa60`00642000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Jan 19 02:56:17 2008 (4791AD21)[/B]
[B]fffffa60`06918000 fffffa60`0692b000 monitor monitor.sys Sat Jan 19 01:32:34 2008 (47919982)[/B]
[B]fffffa60`02bf2000 fffffa60`02bfe000 mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)[/B]
[B]fffffa60`009d8000 fffffa60`009eb000 mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)[/B]
[B]fffffa60`186ea000 fffffa60`18704000 mpsdrv mpsdrv.sys Sat Jan 19 01:35:28 2008 (47919A30)[/B]
[B]fffffa60`18704000 fffffa60`1872b000 mrxdav mrxdav.sys Sat Jan 19 00:55:28 2008 (479190D0)[/B]
[B]fffffa60`1872b000 fffffa60`18753000 mrxsmb mrxsmb.sys Sat Jan 19 00:55:21 2008 (479190C9)[/B]
[B]fffffa60`18753000 fffffa60`1879c000 mrxsmb10 mrxsmb10.sys Sat Jan 19 00:55:07 2008 (479190BB)[/B]
[B]fffffa60`1879c000 fffffa60`187bb000 mrxsmb20 mrxsmb20.sys Sat Jan 19 00:55:19 2008 (479190C7)[/B]
[B]fffffa60`00b33000 fffffa60`00b3d000 msahci msahci.sys Sat Jan 19 01:28:58 2008 (479198AA)[/B]
[B]fffffa60`033e1000 fffffa60`033ec000 Msfs Msfs.SYS Sat Jan 19 00:53:55 2008 (47919073)[/B]
[B]fffffa60`0094d000 fffffa60`00957000 msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)[/B]
[B]fffffa60`00b97000 fffffa60`00bcf000 msiscsi msiscsi.sys Sat Jan 19 01:30:31 2008 (47919907)[/B]
[B]fffffa60`00c87000 fffffa60`00cd7000 msrpc msrpc.sys Sat Jan 19 01:27:01 2008 (47919835)[/B]
[B]fffffa60`03362000 fffffa60`0336d000 mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)[/B]
[B]fffffa60`013e3000 fffffa60`013f5000 mup mup.sys Sat Jan 19 00:54:18 2008 (4791908A)[/B]
[B]fffffa60`00e0b000 fffffa60`00fce000 ndis ndis.sys Sat Jan 19 01:37:13 2008 (47919A99)[/B]
[B]fffffa60`03297000 fffffa60`032a3000 ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)[/B]
[B]fffffa60`069c4000 fffffa60`069cf000 ndisuio ndisuio.sys Sat Jan 19 01:36:29 2008 (47919A6D)[/B]
[B]fffffa60`032a3000 fffffa60`032d4000 ndiswan ndiswan.sys Sat Jan 19 01:37:33 2008 (47919AAD)[/B]
[B]fffffa60`033c4000 fffffa60`033d8000 NDProxy NDProxy.SYS Sat Jan 19 01:37:26 2008 (47919AA6)[/B]
[B]fffffa60`066e1000 fffffa60`066f0000 netbios netbios.sys Sat Jan 19 01:36:35 2008 (47919A73)[/B]
[B]fffffa60`0667f000 fffffa60`066c3000 netbt netbt.sys Sat Jan 19 01:36:24 2008 (47919A68)[/B]
[B]fffffa60`00cd7000 fffffa60`00d2f000 NETIO NETIO.SYS Sat Jan 19 01:37:27 2008 (47919AA7)[/B]
[B]fffffa60`02e08000 fffffa60`0311f000 NETw4v64 NETw4v64.sys Wed Sep 26 09:19:03 2007 (46FA5C47)[/B]
[B]fffffa60`033ec000 fffffa60`033fd000 Npfs Npfs.SYS Sat Jan 19 00:53:57 2008 (47919075)[/B]
[B]fffffa60`06759000 fffffa60`06765000 nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)[/B]
[B]fffff800`0200c000 fffff800`02524000 nt ntkrnlmp.exe Sat Jan 19 01:03:35 2008 (479192B7)[/B]
[B]fffffa60`0120e000 fffffa60`01392000 Ntfs Ntfs.sys Sat Jan 19 00:55:29 2008 (479190D1)[/B]
[B]fffffa60`065c1000 fffffa60`065ca000 Null Null.SYS Thu Nov 02 05:37:15 2006 (4549BC4B)[/B]
[B]fffffa60`06990000 fffffa60`069c4000 nwifi nwifi.sys Sat Jan 19 01:34:38 2008 (479199FE)[/B]
[B]fffffa60`0311f000 fffffa60`03130a00 ohci1394 ohci1394.sys Sat Jan 19 01:34:08 2008 (479199E0)[/B]
[B]fffffa60`066c3000 fffffa60`066e1000 pacer pacer.sys Sat Jan 19 01:36:51 2008 (47919A83)[/B]
[B]fffffa60`00987000 fffffa60`0099c000 partmgr partmgr.sys Sat Jan 19 01:29:14 2008 (479198BA)[/B]
[B]fffffa60`00957000 fffffa60`00987000 pci pci.sys Sat Jan 19 01:02:57 2008 (47919291)[/B]
[B]fffffa60`009c8000 fffffa60`009d8000 PCIIDEX PCIIDEX.SYS Sat Jan 19 01:28:53 2008 (479198A5)[/B]
[B]fffffa60`18895000 fffffa60`1894b000 peauth peauth.sys Mon Oct 23 07:57:00 2006 (453CAE0C)[/B]
[B]fffffa60`06553000 fffffa60`0658e000 portcls portcls.sys Sat Jan 19 01:33:58 2008 (479199D6)[/B]
[B]fffffa60`00642000 fffffa60`00656000 PSHED PSHED.dll Sat Jan 19 02:58:13 2008 (4791AD95)[/B]
[B]fffffa60`03200000 fffffa60`03209000 rasacd rasacd.sys Sat Jan 19 01:37:30 2008 (47919AAA)[/B]
[B]fffffa60`03274000 fffffa60`03297000 rasl2tp rasl2tp.sys Sat Jan 19 01:37:33 2008 (47919AAD)[/B]
[B]fffffa60`032d4000 fffffa60`032e4000 raspppoe raspppoe.sys Sat Jan 19 01:37:30 2008 (47919AAA)[/B]
[B]fffffa60`032e4000 fffffa60`03302000 raspptp raspptp.sys Sat Jan 19 01:37:34 2008 (47919AAE)[/B]
[B]fffffa60`03302000 fffffa60`0331a000 rassstp rassstp.sys Sat Jan 19 01:37:42 2008 (47919AB6)[/B]
[B]fffffa60`0670b000 fffffa60`06759000 rdbss rdbss.sys Sat Jan 19 00:55:09 2008 (479190BD)[/B]
[B]fffffa60`06400000 fffffa60`06409000 RDPCDD RDPCDD.sys Sat Jan 19 01:42:04 2008 (47919BBC)[/B]
[B]fffffa60`033d8000 fffffa60`033e1000 rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)[/B]
[B]fffffa60`03161000 fffffa60`03176000 rimmpx64 rimmpx64.sys Wed Feb 20 20:24:19 2008 (47BCD2C3)[/B]
[B]fffffa60`03176000 fffffa60`0318d000 rimspx64 rimspx64.sys Thu Jul 26 07:33:52 2007 (46A886A0)[/B]
[B]fffffa60`0318d000 fffffa60`031e4000 rixdpx64 rixdpx64.sys Fri Jul 27 06:45:50 2007 (46A9CCDE)[/B]
[B]fffffa60`069cf000 fffffa60`069e7000 rspndr rspndr.sys Sat Jan 19 01:35:48 2008 (47919A44)[/B]
[B]fffffa60`06409000 fffffa60`06552200 RTKVHD64 RTKVHD64.sys Tue Jan 29 22:37:09 2008 (479FF0E5)[/B]
[B]fffffa60`02380000 fffffa60`023ab000 Rtlh64 Rtlh64.sys Thu Feb 14 01:56:12 2008 (47B3E60C)[/B]
[B]fffffa60`03141000 fffffa60`03161000 sdbus sdbus.sys Sat Jan 19 01:02:55 2008 (4791928F)[/B]
[B]fffffa60`1894b000 fffffa60`18956000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)[/B]
[B]fffffa60`00bcf000 fffffa60`00bea000 smb smb.sys Sat Jan 19 01:36:17 2008 (47919A61)[/B]
[B]fffffa60`013db000 fffffa60`013e3000 spldr spldr.sys Thu Jun 21 20:57:56 2007 (467B1E94)[/B]
[B]fffffa60`0220e000 fffffa60`022a8000 spsys spsys.sys Thu Jun 21 21:02:05 2007 (467B1F8D)[/B]
[B]fffffa60`18801000 fffffa60`18895000 srv srv.sys Sat Jan 19 00:57:09 2008 (47919135)[/B]
[B]fffffa60`187bb000 fffffa60`187ec000 srv2 srv2.sys Sat Jan 19 00:56:40 2008 (47919118)[/B]
[B]fffffa60`186a4000 fffffa60`186cc000 srvnet srvnet.sys Sat Jan 19 00:56:38 2008 (47919116)[/B]
[B]fffffa60`0320a000 fffffa60`03267000 storport storport.sys Sat Jan 19 01:29:09 2008 (479198B5)[/B]
[B]fffffa60`0332c000 fffffa60`0332d480 swenum swenum.sys Thu Nov 02 05:37:33 2006 (4549BC5D)[/B]
[B]fffffa60`023ab000 fffffa60`02400000 SynTP SynTP.sys Thu Dec 06 20:42:03 2007 (4758A4EB)[/B]
[B]fffffa60`0100d000 fffffa60`01181000 tcpip tcpip.sys Sat Jan 19 01:38:58 2008 (47919B02)[/B]
[B]fffffa60`18956000 fffffa60`18965000 tcpipreg tcpipreg.sys Sat Jan 19 01:37:01 2008 (47919A8D)[/B]
[B]fffffa60`02400000 fffffa60`0240a000 tdcmdpst tdcmdpst.sys Wed Oct 18 03:08:01 2006 (4535D2D1)[/B]
[B]fffffa60`03267000 fffffa60`03274000 TDI TDI.SYS Sat Jan 19 01:38:11 2008 (47919AD3)[/B]
[B]fffffa60`00dd2000 fffffa60`00def000 tdx tdx.sys Sat Jan 19 01:36:53 2008 (47919A85)[/B]
[B]fffffa60`0331a000 fffffa60`0332c000 termdd termdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)[/B]
[B]fffffa60`00d2f000 fffffa60`00db6000 tos_sps64 tos_sps64.sys Wed Dec 20 00:36:20 2006 (4588CBD4)[/B]
[B]fffff960`00490000 fffff960`0049a000 TSDDD TSDDD.dll unavailable (00000000)[/B]
[B]fffffa60`02311000 fffffa60`0231a000 tunmp tunmp.sys Sat Jan 19 01:36:30 2008 (47919A6E)[/B]
[B]fffffa60`02305000 fffffa60`02311000 tunnel tunnel.sys Sat Jan 19 01:36:44 2008 (47919A7C)[/B]
[B]fffffa60`013d6000 fffffa60`013dae80 TVALZ_O TVALZ_O.SYS Thu Nov 08 22:08:41 2007 (4733CF39)[/B]
[B]fffffa60`0336d000 fffffa60`0337d000 umbus umbus.sys Sat Jan 19 01:34:16 2008 (479199E8)[/B]
[B]fffffa60`067a5000 fffffa60`067c1000 usbccgp usbccgp.sys Sat Jan 19 01:34:04 2008 (479199DC)[/B]
[B]fffffa60`031fa000 fffffa60`031fbe00 USBD USBD.SYS Sat Jan 19 01:33:53 2008 (479199D1)[/B]
[B]fffffa60`02bc0000 fffffa60`02bd1000 usbehci usbehci.sys Sat Jan 19 01:33:57 2008 (479199D5)[/B]
[B]fffffa60`0337d000 fffffa60`033c4000 usbhub usbhub.sys Sat Jan 19 01:34:13 2008 (479199E5)[/B]
[B]fffffa60`0233a000 fffffa60`02380000 USBPORT USBPORT.SYS Sat Jan 19 01:34:00 2008 (479199D8)[/B]
[B]fffffa60`02bb4000 fffffa60`02bc0000 usbuhci usbuhci.sys Sat Jan 19 01:33:56 2008 (479199D4)[/B]
[B]fffffa60`067cc000 fffffa60`067f5300 usbvideo usbvideo.sys Sat Jan 19 01:34:14 2008 (479199E6)[/B]
[B]fffffa60`067c1000 fffffa60`067cc000 UVCFTR_S UVCFTR_S.SYS Tue Nov 27 05:38:38 2007 (474BF3AE)[/B]
[B]fffffa60`065ca000 fffffa60`065d8000 vga vga.sys Sat Jan 19 01:32:21 2008 (47919975)[/B]
[B]fffffa60`065d8000 fffffa60`065fd000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)[/B]
[B]fffffa60`009ac000 fffffa60`009c0000 volmgr volmgr.sys Sat Jan 19 01:29:12 2008 (479198B8)[/B]
[B]fffffa60`00764000 fffffa60`007ca000 volmgrx volmgrx.sys Sat Jan 19 01:29:45 2008 (479198D9)[/B]
[B]fffffa60`01392000 fffffa60`013d6000 volsnap volsnap.sys Sat Jan 19 01:29:47 2008 (479198DB)[/B]
[B]fffffa60`066f0000 fffffa60`0670b000 wanarp wanarp.sys Sat Jan 19 01:37:35 2008 (47919AAF)[/B]
[B]fffffa60`02ba5000 fffffa60`02bb4000 watchdog watchdog.sys Sat Jan 19 01:07:23 2008 (4791939B)[/B]
[B]fffffa60`00806000 fffffa60`008e0000 Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)[/B]
[B]fffffa60`008e0000 fffffa60`008ee000 WDFLDR WDFLDR.SYS Sat Jan 19 01:32:33 2008 (47919981)[/B]
[B]fffff960`000e0000 fffff960`00390000 win32k win32k.sys Sat Jan 19 01:10:09 2008 (47919441)[/B]
[B]fffffa60`00944000 fffffa60`0094d000 WMILIB WMILIB.SYS Sat Jan 19 01:33:45 2008 (479199C9)[/B]
[B]Unloaded modules:[/B]
[B]fffffa60`01200000 fffffa60`0120e000 crashdmp.sys[/B]
[B]Timestamp: unavailable (00000000)[/B]
[B]Checksum: 00000000[/B]
[B]fffffa60`02201000 fffffa60`02305000 dump_iaStor.[/B]
