System Lockups
  1. #1
    Junior Member
    Vista x64
    Local Time: 03:45 PM
    System Lockups
    Hey,
    Lately my Vista machine has been acting weird. When in any program whether it be, FireFox, Chrome, Minecraft, etc. The program will "Stop responding" and then everything else on my system will stop responding also, then it will freeze for about 30 seconds, this happens almost every 5 minutes.
    It was happening so I formatted my HDD and re-installed Vista, but it still is happening, I'm not sure if its a hardware issue or not. I doubt there is anything on my system that could cause this to happen, nor have I overclocked anything, other than my GPU which was overlocked (black edition) when I bought it new.
    I have also looked at my temperatures, nothing seems unusual, my GPU runs around 55C idle, and my CPU runs around 38C idle, my chassis temp is around 30C, and I have also cleaned my system out from any dust/hair, etc. I'm pretty sure all my drivers are up to date.
    Specs:
    AMD Phenom II x6 1055T 2.80GHz
    ATI/AMD HD5850 1GB GDDR5
    8GB DDR3 1666MHz RAM
    Retail +Plus 650 WATT PSU
    Asus M4A77T/USB3 motherboard
    1TB WD 7200RPM HDD
    So can anyone help me figure out what might be the problem as this is really making my frustrated.
    Thanks,
    Archey
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 05:45 PM
    usa us connecticut
    Re: System Lockups
    Welcome
    Here are my solutions to freezing, and an excellent article, which I hope is of some help
    Go to search type device manager and look for any yellow warning markers
    Download and run malwarebytes, a full scan after you update
    Run antivirus scan
    Check memory with memtest86
    Make sure that you are not over heating.
    Try in safe mode; report back if it works properly.
    Try a clean boot
    Make sure PSU is working properly
    If overclocking, restore to original
    Test hard drive at company website.
    Test in safe mode, does it still happen?
    Try with clean boot..
    http://support.microsoft.com/kb/929135
    http://malwarebytes.org/
    http://www.almico.com/speedfan.php
    http://www.geekstogo.com/forum/topic...ing-memtest86/
    http://ezinearticles.com/?Troublesho...blems&id=39981
  3. #3
    Junior Member
    Vista x64
      Thread Starter
    Re: System Lockups
    - No point to run AV scan, as its a clean OS.
    - Memtest won't help as I've swapped out for brand new ram, still happens.
    - Safe mode won't really do much since its a new OS, and It happens while running programs.
    - Not OCed
    - Have monitored hear, they're normal.
    - Not sure how to tell if my PSU is faulty but I've had it for about 2 years
  4. #4
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Re: System Lockups
    Quote Originally Posted by Archey View Post
    - Not OCed
    Run memory test, possibly you need to reseat the sticks
    Run in safe mode and give me the results
    Read the post, unless you have done the specific test, do it now.
  5. #5
    Junior Member
    Vista x64
      Thread Starter
    Re: System Lockups
    Quote Originally Posted by richc46 View Post
    - Not OCed
    I've tried running memtest86, when i downloaded it, it was just a bunch of source files, is there a guide on how to install it?
  6. #6
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Re: System Lockups
    This may help
    Guide to using Memtest86+ - Geeks to Go Forums
    Start with safe mode. If you do not have a problem with safe mode, we can probably determine the cause with a clean boot.
  7. #7
    Junior Member
    Vista x64
      Thread Starter
    Re: System Lockups
    Well ran in Safe mode with Networking, Did some browsing on the internet testing out lockups and it didn't seem to crash. It's weird because about a month back it was doing this, I formatted and re-installed and it kept on.
  8. #8
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Re: System Lockups
    Maybe we found something. Perform a clean boot. This may give us the cause
    How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
  9. #9
    Junior Member
    Vista x64
      Thread Starter
    Re: System Lockups
    link you gave gives a 404
  10. #10
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Re: System Lockups
    Try it again, it worked just now when I tried.
Page 1 of 2 12 LastLast
System Lockups
Intermittent System Lockups/BSoD djhawk Crashes and Debugging 29 26 Feb 2011
Sudden system lockups? why? Tizzy Vista performance & maintenance 5 22 Aug 2007
Lockups xoted Vista performance & maintenance 1 18 Oct 2006
System Lockups John Pendleton Vista installation & setup 0 13 Jun 2006
Random System Lockups when Uploading - Extremely baffling bug Adahn Vista networking & sharing 1 13 May 2006
