Vista Home Premium 32-bit Service Pack 2
Local Time: 05:14 PM
Start Up Repair not working
As the title says the Start Up Repair is failing to fix system errors. When I try to run Windows normally, it gets past the loading screen - then a black screen instead of going to the login page - then it restarts. This also happens when I try to reboot using last known good configuration. It boots fine in Safe Mode - and I am currently running it with Networking.
Anyway, this is the errors that I received from the Start Up Repair.
Problem Event Name: Startup Repair V2
Problem Signature 01: AutoFallover (or AutoFailOver?)
Problem Signature 02: 6.0.6000.16386.6.0.6001.18000
Problem Signature 03: 3
Problem Signature 04: 65537
Problem Signature 05: unknown
Problem Signature 06: NoRoot cause
Problem Signature 07: 0
Problem Signature 08: 2
Problem Signature 09: WrpRepair
Problem Signature 10: 2
OS Version: 6.0.6000.2.0.256.1
Level ID: 1033
The computer needs to be fixed - I need it badly for my coursework - I can't afford to lose any data if possible. There was no Vista Disk with the computer either.
Hello, while in your current mode , you should still be able to do this : System Files - SFC Command Give it a shot and see if it can fix anything. Most recommend running it 4 or 5 times as running it only once may not repair all files.
System Manufacturer/Model Number Emachine ET 1161-05 OS Vista Home Basic. 32 bit SP 2 CPU AMD Athlon 64 LE-1640 Motherboard eMachines MCP61PM-GM (Socket AM2 ) Memory 2.00 GB Dual-Channel DDR2 @ 387MHz (6-6-6-18) Graphics Card Acer E181H (1280x768@60Hz) 128MB GeForce 6150SE nForce 430 ( Sound Card Realtek High Definition Audio Monitor(s) Displays Name Acer E181H on NVIDIA GeForce 6150SE nForce 430 Screen Resolution 1280x768 pixels
Keyboard Standard PS/2 Keyboard Mouse PS/2 Compatible Mouse PSU MCP61PM-GM 9000 NVIDIA Chipset Model MCP61 Chipset Revisio Case Tower Cooling Fan Speed 1247 RPM Hard Drives ST316081 5AS SCSI Disk Device Internet Speed http://www.speedtest.net/result/1538974261.png
Vista 64 Home Premiium
Re: Start Up Repair not working
I had a similar problem. I took the case off disconnected the smart media card, blew it out with compressed air. Working again. This can keep your computer from booting up. Unfortunately I learned this after doing a system factory reset which created it's on set of problems. Just mentioning as could be your cause.
System Manufacturer/Model Number Self Built OS Windows 7 home premium 64 bit CPU I5 3570K Motherboard Gigabyte Z77-DS3H Memory 4 x 4GB corsair ballistix sport DDR3 1600 Mhz Graphics Card Gigabyte Geforce GTX 660 TI Sound Card creative x-fi Monitor(s) Displays Primary CiBox 22" Widescreen LCD ,Secondary Dell 22" Widescreen Screen Resolution Both 1680 x 1050
Keyboard Logik Mouse Technika TKOPTM2 PSU Corsair HX 620W ATX2.2 Modular SLI Complient PSU Case Antec 900 Ultimate Gaming Case Cooling 3 x 80mm tri led front, 120mm side 120mm back, 200mm top Hard Drives 2 x 500G HD (SATA) 1 x 2TB USB Internet Speed 288 / 4000 Other Info Creative Inspire 7.1 T7900 Speakers
Trust Graphics Tablet
