memory problems
  1. #1
    Newbie
    Vista Ultimate x64
    Local Time: 01:20 PM
    memory problems
    My laptop broke a while ago and after speaking to a help line they told me to restore my laptop to factory settings. I did this which meant I lost everything on my computer. When I started to put music back on my laptop it said I didnt have enough memory which is mad because i dont have anything on my laptop. it also says that my recovery disc is full so i dont know if this is linked to my memory? can anyone help me? thanks
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 03:20 PM
    usa us connecticut
    Re: memory problems
    Hit alt cntrl delete and bring up task manager
    then click on show process from all users then
    Click the process tab
    Then click on memory to bring the big memory users to the top
    Upload a screen shot to us.
  3. #3
    Senior Member
    Ultimate x64, home Prem 64
    canada
    Re: memory problems
    I believe you mean Hard drive space.
    Which isn't a surprise, as a reinstall actually saves all your stuff in a folder called c:\windows.old or something like that, and it can be huge.
    Look for it, as if you saved your music in your profile, it may be still there.
  4. #4
    NoelDP's Avatar
    Three-Toed Sloth
    Wales - usually in the pub :)
    Vista HP 32-bit (also 64-bit VM)
    Local Time: 08:20 PM
    uk uk wales
    Re: memory problems
    The factory recvoery usually just reformats the C: drive - although there are some which will do less.
    It's possible that the reinstall went into the wrong partition and is limited.
    @Isabel
    please run the following commands in an Elevated Command Prompt window
    diskpart
    (wait for the prompt to change)
    LIST VOLUME
    EXIT
    copy and paste the output to your response.
    1) To open an Elevated Command Prompt Window (the CP window), click on Start, All Programs, Accessories – then right-click on Command Prompt, and select Run as Administrator. Accept the UAC prompt.
    2) To run the commands easier, highlight the block of commands, and right-click on the highlight – select Copy. In the CP Windows, click on the black/white icon at top left – select Paste. The commands will run but may not complete the last command, so hit the Enter Key once.
    ) To copy the results... click on the Black/White icon in the top left, and select Edit... 'Select All', and hit the Enter key - then use Ctrl+V or r-click+Paste to paste it into your response.
memory problems
2 different vista problems. Memory dump crash and startup repair cannot fix problems Hiera Vista General 4 28 Jun 2008
Memory Problems Jath Vista hardware & devices 0 10 Jun 2008
Memory Problems!!!!!!!!!!! John Lagree Vista hardware & devices 6 02 May 2008
Memory problems asiandoll Vista General 5 31 Dec 2007
Memory Problems Gogless Vista hardware & devices 0 21 Apr 2007
