br> br> |
| | Thread Tools | Display Modes |
| Junior Member Rep Power: 6 ![]() | SD Card Driver Problem Hi, I am having a problem with my Ricoh SD/MMC Host Controller and the SD Host Adapter (that is natively installed by Vista) on my laptop. When my SD card works, I can see that both of the Host Controllers are available in the Device Manager, however the next day when I turn on my Computer, both options will dissapear in the Device Manager and my SD Card will not work. I tried to forcefully install the Ricoh SD/MMC Host Controller again using the "Legacy Driver" option and it gave me a blue screen of death from which I couldn't even boot Windows to safe mode. I then went to "Last Known Good Configuration" and then the Ricoh SD/MMC Host Controller and the SD Host Adapter were back in the Device Manager. The next day however, the same issue occured in which both Controllers dissapeared .Why is this happening? I have the latest drivers installed from ASUS (my laptop manufacturer). PS: Today in the morning it dissapeared once again, I happened to put my computer on stand-by for a few minutes, and then when I turned it back on, both controllers appeared again . It only dissapears the next day (when I leave the computer off for a very long time), because if I try to restart the computer 10 times, it will stay there. |
| Newbie Rep Power: 7 ![]() | Re: SD Card Driver Problem Can it be, that the power management switch off your device? |
| Junior Member Rep Power: 6 ![]() | Re: SD Card Driver Problem Hi, I don't think it has anything to do with power management because this only affects the SD/MMC Driver. The Memory Stick and xD drivers work perfectly fine and they are all referring to the same device. |
| Display Modes | |
| NVIDIA Video card driver problem | Jones18 | Drivers | 7 | 06-27-2008 10:16 PM |
| Wonder Pro TV Card Driver Installation Problem | mashudu | Drivers | 1 | 04-29-2008 08:08 AM |
| please Help >>=> Windows Media Player cannot play this DVD because there is a problem with digital copy protection between your DVD drive, decoder, and video card. Try installing an updated driver for your video card. | Rono | Vista General | 1 | 03-21-2008 09:14 AM |
| driver problem with tv tuner card.. | Pradeep | Vista General | 4 | 07-15-2007 12:56 PM |
| sd card driver problem | Furie | Vista installation & setup | 5 | 07-14-2007 05:03 PM |
