Go Back   Vista Forums > Vista Forums > Drivers
Vista - GSA-H20L DVD recorder driver problem
Old 04-16-2008   #1 (permalink)
Vista Ultimate x64
After install Vista x64 a get this error:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
On windows XP x32 everythink was working fine.
Firmware, BIOS and Windows are all up to date. Is there any chance to use XP DVD drivers under Vista or where can I find a working one?
Regards
Piotr
Old 04-30-2008   #2 (permalink)
Windows Vista Ultimate x86
Re: GSA-H20L DVD recorder driver problem
hi piotr,
please take a look at this link
Asus drw-2014l1t DVD not working
tell me if it works or not...
Vista Sound Recorder problem Vista General
for user that have the driver problem driver. How do we clean inst Vista installation & setup
Recording Problem with sound recorder Vista music pictures video
RE: Vista install problem - Failed to add driver package into driver s Vista installation & setup
GSA-H20L A required CD/DVD drive device is missing. Vista General
