| Vista x64 Ultimate | USB Stick with Finger Print - x64 Problem Hi! I just bought a new USB Flash drive (Apacer 8GB), which features a finger print reader. The reason: I want to store my Outlook / OneNote files on it, so I can use them on different computers in different networks. Now the problem: On the box it says "Vista 32bit". Unfortunately this was never mentioned on the web, where i bought it. I started the Fingerverify.exe and it loads, however after loading it just ends itself without showing the verification diaglog. Does anybody know, if (and) how i can get around this? I tried to open in XP and even Win98 compatibility mode but it does not help either. Google does not show anything as well... Thanks for your help, Jan |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: USB Stick with Finger Print - x64 Problem That is going to be a driver issue - you'll need to locate Vista x64 compatible drivers for that stick for that to work. |
| Does the Hp6730s laptop has finger print reader/scanner?? | Drivers | |||
| Cannot Install Digital Persona finger print as Biometric Logon service cannot be star | Drivers | |||
| SP1 , and USB stick problem | Vista General | |||
| print driver successfully installed but still a problem with print | Vista print fax & scan | |||
| Monitoring a processes resource finger-print | PowerShell | |||
