Go Back   Vista Forums > Vista Forums > Drivers
Vista - Brother HL-1440 shared printer problems
Old 08-23-2008   #1 (permalink)
Vista Enterpise 32bit
I am running Vista Ultimate 64bit on my desktop. I have installed my Brother HL-1440 with no problems. My problem occurs when I try and add the printer as a shared printer to my father's desktop that is running XP. File sharing works between both computers with no problem. The XP box sees the printer and when I tell it to add it as a shared printer I get a message saying the printer server doesn't have the correct drivers installed. I click ok and go to the next screen where I try and point the OS to the correct drivers. I have downloaded the XP drivers from Brother's website. When I try and manually direct the OS to them I get a message saying the .INF is wrong.
My networking buddy has told me that this same problem occured for him back with NT and win98 and that the fix was installing the 98 drivers on the NT box. I have researched adding drivers into Vista's driver store file but am confused about that whole thing, plus I'm not positive that will fix this issue. I have looked at
Michael Niehaus' Windows and Office deployment ramblings : Windows Vista driver management
Device Management and Installation Step-by-Step Guide: Signing and Staging Device Drivers
Is the solution present on one of these pages and if so can someone simplify it for me.
Thank you.
Problems with a shared printer Vista networking & sharing
Shared Printer Problems Network & Sharing
Printing to Brother HL-1440 comes out garbled Vista print fax & scan
Connection problems for shared printer Vista networking & sharing
Solution to Brother HL 1440 Vista X64 network driver problem Vista print fax & scan
