| vista 32bit | ATA Controller Problem Have the following error message on controller standard AHCI 1.0 Serial ATA Controller PCI\VEN_197B&DEV_2360&SUBSYS_82081043&REV_02\4&2212B143&070038 This device cannot start Error code 10 have tried to disable and enable device....still will not work properly any help would be appreciated.....thanks |
| Vista Home Premium x64 | Re: ATA Controller Problem Have you tired going to the device manager, right clicking and selecting up date driver? If that doesn't work, try uninstalling the driver, rebooting and letting windows reinstall it. You might want to check the cables to see if they are seated good on the drive and if this controller is a card, make sure it is seated good. If all that fails, you may have a hardware failure (drive, cable or card) |
| Vista Ultimate x64 SP1 | Re: ATA Controller Problem What are your system's specs? |
| Xbox 360 controller problem | Gaming | |||
| Storage Controller Problem | Vista hardware & devices | |||
| problem with igfx controller | Vista General | |||
| PCI Simple Comm Controller & Mass Storage Controller drivers: Miss | Vista hardware & devices | |||
| PCI Simple Com Controller & Mass Storage Controller drivers: Missi | Vista hardware & devices | |||
