Go Back   Vista Forums > Vista Forums > Drivers
Vista Tutorial - converting 32bit driver to 64bit...
Old 09-27-2008   #1 (permalink)
Newbie
32bit
I wrote a 32bit driver and now want to convert it to 64bit.
The driver is writing in gpd. See the first 8 lines of the source code below.
*GPDSpecVersion: "1.0"
*Include: "StdNames.gpd"
*GPDFileVersion: "1.0"
*GPDFileName: "eswlhfax.GPD"
*ModelName: "ElectraSoft Vista Fax"
*MasterUnits: PAIR(200, 200)
*ResourceDLL: "ESWLHFAX.Dll"
*PrinterType: SERIAL
Thank you,
Jon
64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions General Discussion
is it possible for one driver to be for both 32bit and 64bit OS? Vista hardware & devices
Free ASPI driver for WinVista 32bit and maybe WinVista 64bit Drivers
Error -Failing to update driver with Vista 32bit and 64bit systems Vista hardware & devices
Use XP driver in Vista? 32bit vs 64bit? Vista hardware & devices
