Go Back   Vista Forums > Vista Forums > Drivers
Vista - TTSTcorp DVP+-RW TS-L632D not working...HELP :*(
Old 11-05-2008   #1 (permalink)
Windows Vista Ultimate 32bit
Earlier today I tried to install Oblivion onto my computer to find that my dvd drive isn't working for some reason. It does not even show up under computer --> hard disk drives. I looked it up under device manager to find a yellow triangle next to TTSTcorp DVP+-RW TS-L632D and under the general tab it says "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Could someone please guide me as to how I may be able to remedy this unfortunate situation? I'm not too computer savvy so please take that under consideration. running 32 bit windows vista ultimate
Old 11-05-2008   #2 (permalink)
Re: TTSTcorp DVP+-RW TS-L632D not working...HELP :*(
Nevermind I fixed it through the registry
Old 11-09-2008   #3 (permalink)
Ultimate x64 SP2
Seems to be somewhat of a common problem with Toshiba laptops!
Old 11-09-2008   #4 (permalink)
Vista home premium 32 bit
yeah having the same problem here with the tsstcorp-cd-dvdw-ts-h652h-ata-device, its in an emachine with vista home premium 32 bit . not too savy with the registry , can someone offer a suggestion or solution to this problem I tried to do an uninstall and restarted the pc , it dectected the hardware but failed to install the driver , got same code 39 error.
tsstcorp cd dvdw ts-l632d ata device not burning cds Drivers
TSSTcorp DVD+-RW TS-L632D ATA Device Drivers
tsst corp cd/dvdw ts-l632d ata device Drivers
TSSTcorp DVD+-RW TS-L632D ATA Probelm with it, i want to game! Gaming
my cd/dvdw ts l632d ata devices Vista hardware & devices
