Go Back   Vista Forums > Vista Forums > Drivers
Vista - driver problem: Compocessor & SM Bus Controller
Old 12-01-2008   #1 (permalink)
Windows Vista Ultimate 64-bit Service Pack 1
Hi every one,
i have installed Windows Vista Ultimate 64-bit
and i have installed all the drivers using the CD's coming with the motherboard and the graphics display adapter.
but still having these two drivers that i can't find them
- Compocessor
- SM Bus Controller
please, can you help me get the drivers for these two elements
PC details:
Processor: AMD Phenom X4 9950 Black Edition
Motherboard: XFX GeForce 8300 ( 1066MHZ)
Display Adapter: XFX GeForce 9500GT 512MB DDR3
RAM: Kingston DDR2 1066MHZ 2GB ( 2 pieces 2GB each)
HDD: SATA Western Digital 1T.B
thanks in advance.
Old 12-01-2008   #2 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: driver problem: Compocessor & SM Bus Controller
Hi CityStars and welcome to Vista Forums
What is the model number of your motherboard (refer to the manual)? What you have quoted appears to be a graphics card GeForce whereas a motherboard would be nForce.
Old 12-01-2008   #3 (permalink)
Dear Dwarf, thanks for welcoming me here, it is much appreciated.
about the motherboard model, i will try to give you as much information as i can.
i think the model number is: XFX GeForce 8300 motherboard
here is the some pictures of my motherboard:
you can see more here:
XFX GeForce 8300a mATX Motherboard XFX GeForce 8300 mATX Motherboard [33X-N8300A] - $148.00 : PC Case Gear, Quality case accessories and components
Материнские платы GeForce 8300 и nForce 750a от XFX | Компьютеры и техника
i hope i provided the information you need.
Thanks again.
Old 12-01-2008   #4 (permalink)
Vista Premium x64
Interesting Mainboard kinda raises more questions about naming usage lol, but the SM Bus Controller should be located on the mainboard driver disk that would have come with the board and as for Compocessor i believe its something to do with language type of thing which makes me feel it proberly should be either on the Windows disc or from external third party like one of the following:
Abstract
Association based Natural Language Processing with Neural Networks KIMURA Kazuhiro SUZUOKA Takashi AMANO Sin Information Systems Laboratory Research and Development Center TOSHIBA Corp Komukai siba Saiwai Kawasaki Japan kim isl rdc toshiba derstanding the practical treatment context dependency within the language can also This paper describes natural language pro improved enhancing underlying compocessing system reinforced the use associ nent technologies such knowledge based ation words and concepts implemented systems particular alternate approaches neural network Combining associative net symbolic manipulation provided connecwork with conventional system contributes tionist models Rumelhart have emerged semantic disambiguation the process Connectionist approaches enable the extracinterpretation The model employed within tion processing knowledge from examples kana kanji conversion system and the advan instead building knowledge bases manually tages over conventional ones are shown The model described here represents the unification the connectionist approach and conventional symbolic manipulation its most Introduction valuable feature the use word associations using neural network technology Currently most practical applications natWord and concept associations appear ural language processing NLP have been central human cognition Minsky realized via symbolic manipulation engines Therefore simulating word associations consuch grammar parsers However the curtributes semantic
Unless i am getting this part wrong but dont quote me on last bit
Its proberly not a vital thing but never really heard the term Compocessor used before.
Old 12-02-2008   #5 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
You can use this URL Motherboards - GeForce Series - GeForce® 8300 to contact XFX about this motherboard to see if they have any answers for you....
Old 12-02-2008   #6 (permalink)
Thanks to you all, now i solved the problem when i downloaded the nForce Driver from the NVIDIA website as the chipset is manufactured by NVIDIA, i guess that the SM Bus Controller and Compocessor are things related to the Motherboard Chipset.
Thanks again for your efforts, Vista Forums is the best.
Old 12-02-2008   #7 (permalink)
Vista Ultimate x64
nForce 15.24,
nForce Driver
Quote:
  • Ethernet Driver (v67.89) WHQL
  • Network Management Tools (v67.91) "Sedona"
  • SATAIDE Driver (v10.3.0.42) WHQL
  • SATARAID Driver (v10.3.0.42) WHQL
  • RAIDTOOL Application (v10.3.0.42)
  • SMU Driver (v1.61) WHQL
  • SMBus Driver (v4.69) WHQL
  • Away Mode Driver (v6.0.6000.107) WHQL
  • Installer (v6.14)
should do the trick. Also do not install the two that are bolded; the first can be more trouble than it is worth, and still no idea what the second is supposed to do (can't find a straight answer anywhere ATM). Just make sure to uncheck them during the install.
P.S. here is the download page for an Asus board with the same chipset,
ASUSTeK Computer Inc.-Support-
Just get them from the Nvidia link as the download from Asus includes everything (motherboard and video) for both XP 32 and 64 bit as well as Vista 32 and 64 bit 9Basically 4 different driver packages in one and why it is over 500 MB).
P.S. Despite it not showing in the list of included drivers there is also a video driver included (not sure which version, but one from the 17x.xx series I believe) that you don't need to install. In fact you would probably be better off using the latest video driver (180.48) for your card,
http://www.nvidia.com/object/winvist...0.48_whql.html
Old 12-02-2008   #8 (permalink)
Windows 7 RC x64 Vista HP x86
Hi stormy,
This may help explain "Away Mode"
Away Mode in Windows Vista
As you say it's an Optional thing and the only reference to it, I have noticed, is an option in Power Options
Old 12-02-2008   #9 (permalink)
Quote  Quote: Originally Posted by stormy13 View Post
nForce 15.24,
nForce Driver
  • Installer (v6.14)
This is the exact nForce driver i have downloaded and used and it solved the problem.
SM Bus Controller driver Drivers
Yet another NVIDIA nForce networking controller driver problem. Network & Sharing
Graphics Controller Driver Update Problem Vista General
Problem caused by Serial ATA Storage Controller Driver Vista General
Vista SLOW - Intel 82801FR RAID Controller Driver Problem? Vista hardware & devices
Designer Media Ltd
