Go Back   Vista Forums > Vista Forums > Drivers
Vista - Vista 64 Geforce 260 driver problem
Old 12-25-2008   #1 (permalink)
Vsta Ultimate 64
Hi I just reinstaleld windows vista 64 ultimate and I installed the gpu driver and when I restart when the vista loading screen is finished it goes to a blank screen for about 5-10 secs and then the moniter just says their is no connection or something I have never had this problem
amd 9850 stock 8gigs corsair xms2 evga 260ssc 150velocity raptor 1k antec psu m3n78pro mobo
merry xmas and happy holidays
Old 12-25-2008   #2 (permalink)
Vista Ultimate x64 SP1
Re: Vista 64 Geforce 260 driver problem
Check that the card is seated properly and you have the 4-pin connector connected to the card.
Old 12-25-2008   #3 (permalink)
Vsta Ultimate 64
Hey thanks Ill try that right now.
Old 12-25-2008   #4 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Also, *which driver did you install? I have one of those SLI'd with a stock 260 (and am using eVGA's Precision utility to OC both to 636 MHz / 1107 MHz / 65% rpms) and have not had a single problem with any of the drivers, neither the 'current' 180.48 nor the Beta 180.84 and 181.00
Old 12-25-2008   #5 (permalink)
Vsta Ultimate 64
Well first I went to the website and installed the 180.48 and when it gets to the login screen it just goes blank so i installed windows again because i have no idea how to get by that so i tried the cd that came with it i think its 174 or something but yeah i had to re install vista and this is my second time doing this and i have not had this problem before and to the other answer yes the two 8 pin conectors are plugged in I have 2 other ones that came with my psu should i try those?
Thanks for the support on the holiday
Old 12-25-2008   #6 (permalink)
where are the 8 pin connectors coming from? although I doubt that power here is an issue as if the card were underpowered you'd get a nice big fat message on the screen complaining about power as soon as the system were powered on....
Right now, are you on a brand new Vista installation with no drivers installed?
Old 12-25-2008   #7 (permalink)
Vsta Ultimate 64
I have my motherboard drivers for internet and all that stuff my mobo is a m3n78 pro
Thanks
Old 12-25-2008   #8 (permalink)
*from* the Internet? Again, *which* version?
Old 12-25-2008   #9 (permalink)
Vsta Ultimate 64
The motherboard drivers are from the cd the chipset is 4.6.4.0 the audio driver is 6.0.1.5618 the hdmi driver is 1.00.00.23
Right now on the video settings it says generic-non-pnp on standard vga graphics adapter and i am using my 260 connected by a dvi cable
I have no real video driver on here i guess
thanks
Old 12-25-2008   #10 (permalink)
I asked about the driver version for the GTX260. The one that you tried - the one that failed.
Uninstalling nvidia geforce driver problem Drivers
Geforce 260 driver update problem Drivers
Vista 64 geforce 260 driver problem Graphic cards
Geforce 260 driver problem VIsta 64 Drivers
nvidia GeForce FX 5200 card driver incompatible with GeForce 7600GS ?? - 4 monitors Vista installation & setup
