| Vista Ultimate x64 | USB driver problem - kind of Hi peeps, I have two problems that i hope you can help me with. The first problem:- Everytime i switch my pc on my usb's dont work. They had been working fine for several weeks but they went wrong. When i go into device manager the properties for them say "This device cannot start (code 10). Windows did not start a related device driver. To learn more, click the driver tab and then click driver details." The driver tab shows that drivers are installed and does not show any problem. All i need to do to make them work again is to uninstall them (no need to delete drivers) and let the system find and install them again. They then work perfect until the next time i start the pc. The second problem is putting the pc to sleep. It goes to sleep fine but a couple of seconds after starts up again on its own. Any idea's anybody ? This is doing my head in. Thanks in advance. Chris |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: USB driver problem - kind of Hi Chris and welcome to Vista Forums ![]() It is posssible that your problems might be related. Have a look at this Tutorial to see if it helps: Power Options and Sleep Mode Problems |
| Vista Ultimate x64 | Re: USB driver problem - kind of Thanks for that. It was the usb mouse that was causing the pc to wake up immediatly. I still have the usb driver problem though. Any idea's about that one ? Chris |
| Vista Ultimate x64 | Re: USB driver problem - kind of I'm seeing the same problem... Has anyone been able to find a resolution yet? Thanks!!! |
| Vista Ultimate x64 | Re: USB driver problem - kind of i guess nobody knows the answer to this one ? |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: USB driver problem - kind of For me, it turned out to be the AT&T Communication Manager software for my aircard. After reverting to a restore point just before installing that, everything was fine. I don't know if that helps or not....... -Chris |
| | #7 (permalink) |
| Vista Ultimate x64 | Re: USB driver problem - kind of which was your problem - the usb's not working or the waking up from sleep automatically ? I have already sorted the latter but the first is an extremely annoying problem |
| | #8 (permalink) |
| Vista Ultimate x64 | Re: USB driver problem - kind of I had the same USB problem you did ('related driver failed to start...') - on almost all of the "Intel ICH8 USB Host Controller" devices. Turns out AT&T CM was messing it up somehow. Without that on there, laptop runs fine. |
| would some one be kind enough to help me | General Discussion | |||
| Will someone please be kind enough to help me? | Vista General | |||
| for user that have the driver problem driver. How do we clean inst | Vista installation & setup | |||
| RE: Vista install problem - Failed to add driver package into driver s | Vista installation & setup | |||
| The kind of Vista problem MVP's hate to see and can't make excuses for | Vista General | |||
