Go Back   Vista Forums > Vista Forums > Drivers
Vista - Pinting problem with HP laserjet 1200
Old 01-07-2009   #1 (permalink)
Windows Home basic 32
I am using an auto printer switch hub to connect to computers to one HP Laserjet 1200 printer. One computer uses Vista Basic the other uses XP. I am getting a printing error error and the document won’t print or it takes a long time then prints garbage. Any fix to this problem?
LaserJet 1200 printer installed but not scanner Vista print fax & scan
HP Laserjet 1500 problem Software
Vista, HP Laserjet, Top Margin Problem Vista print fax & scan
Problem with shared Laserjet printer Vista print fax & scan
HP laserjet 1012/Vista problem Vista hardware & devices
