Go Back   Vista Forums > Vista Forums > Drivers
Vista - Problem with Pioneer Dvd burner
Old 01-14-2009   #1 (permalink)
vista 32bit
My SONY VAIO VGN-Cr290 Laptop has a PIONEER DVD-RW DVR-K17 ATA.
When I am trying to burn a data DVD, burning speed is only 2.3X
I am using DVD+R (as I always do) But not only does it burn slow it doesn't read after I get the "Burn Successful" message.
I contacted Sony and they couldn't figure it out, they said to do a system restore.....I did as far back as it would let me and problem still exist.
Checked Device Manager/IDE ATA/ATAPI controllers and DMA is enabled on all channels. and updated all drivers (none needed an update)
Burns and reads CD-r OK!
Am I missing something, any help would be great.
Window Vista OS
Burning using Nero (also tried burning using windows, no luck, same problem)
Old 01-15-2009   #2 (permalink)
vista 32bit
Re: Problem with Pioneer Dvd burner
nobody? anybody?
Burner Problem Vista hardware & devices
problem with dvd burner General Discussion
CD Burner Problem Software
Pioneer DVR-710 DVD Reader/Burner Unable to be Recognized by Vista Vista hardware & devices
CD Burner problem Vista General
