| Vista Home Premium 32bit | Zydas major problem i tried to uninstall zydas to install again but it wont let me it says you wanna completly remove everything i put yes and when i try installing again i just found it that the installer didnt remove zydas files i used a program to delete them manually but zydas install still says do you wanna remove zydas from your pc please help asap i gotta play with a friend on XLINK kai ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET | Re: Zydas major problem Try using Revo Uninstaller on the advanced tab to uninstall it. Download Revo Uninstaller Freeware - Free and Full Download |
| A major problem | Live Mail | |||
| Major Problem, please help | System Security | |||
| Help need!OS problem Major | General Discussion | |||
| MAJOR Problem! Help! | General Discussion | |||
| ZyDAS Wifi problem. can't seem to fix it | Vista hardware & devices | |||
