Go Back   Vista Forums > Vista Forums > Drivers
Vista - Re-printing problem
Old 02-11-2009   #1 (permalink)
Vista Home Basic 32bit
Re-printing problem
I am having trouble with my print drive. When I shut my computer down in the evening and then start it back up the next day, all of the print jobs from the previous day are re-printing. I have already ran a windows repair to see if that was the problem and unistalled and re-installed the print drive. I did not see anything during the installation process that I could have checked that would be causing this problem, however, the same issue exists. I also have the problem of my system re-starting itself at random times when I don't want it too. Don't know if the two issued are linked together? I'm hoping someone can help me on this.
Old 02-11-2009   #2 (permalink)
Windows 7 x64 build 7100 & Ubuntu 9.04
Re: Re-printing problem
Hello vrsheetmetal.
Disable the device from Device Manager, and then uninstall the Driver. Plug the printer back in after a restart, and let Vista install the drivers. Their driver may have been causing conflicts.
~Lordbob
Old 02-12-2009   #3 (permalink)
Vista Bussiness x64 PL
Printing Problem Live Mail
Printing problem Vista print fax & scan
printing problem Vista General
printing problem Vista print fax & scan
Printing Problem Vista print fax & scan
