Go Back   Vista Forums > Vista Forums > Drivers
Vista - Simple Intellitype pro problem?
Old 02-12-2009   #1 (permalink)
Vista home premium, 32 bit
I have just bought the sidewinder X6 keyboard and the sidewinder mouse.
I downloaded Intellipoint and intellitype pro and installed both successfully.
But, when I open either help screen the text in the right hand pane is to small to read (on a 24 inch screen)
The text in the naviagtion pane on the left is fine, i.e. normal size.
I have tried resizing the window to no avail. I can't see any other option.
Help please, thanks
Old 02-12-2009   #2 (permalink)
Re: Simple Intellitype pro problem?
Well, downloaded both software packages to my laptop (desktop before). Text size is as it should be?
I'm confused but at least I can now read it.
simple problem Network & Sharing
Problem reassigning special function keys IntelliType Pro Vista hardware & devices
Help with simple keyboard problem General Discussion
Intellitype & Dell laptop keyboard problem Vista hardware & devices
